Resuming a SnapVault relationship with Data ONTAP operating in 7-Mode
If you restore using a Snapshot backup other than the latest one, you need to resume the SnapVault relationship so that Snap Creator can continue to run backups.
Resume the SnapVault relationship with Data ONTAP operating in 7-Mode by entering the following command. snapvault start -r -S source_controller:source_volumebackup_controller:backup_volume
Perform this step for all volumes belonging to the SAP HANA database.
hana2b> snapvault start -r -S hana1a:/vol/data_00001/mnt00001 hana2b:/vol/backup_data_00001/mnt00001 The resync base snapshot will be: Backup-ANA-SV_daily_20140406200000 Resync may alter the data in this qtree. Are you sure you want to resync the qtree? y Mon Apr 7 14:08:21 CEST [hana2b:replication.dst.resync.success:notice]: SnapVault resync of /vol/backup_data_00001/mnt00001 to hana1a:/vol/data_00001/mnt00001 was successful. Transfer started. Monitor progress with 'snapvault status' or the snapmirror log.
hana2b> snapvault start -r -S hana1b:/vol/data_00002/mnt00002 hana2b:/vol/backup_data_00002/mnt00002 The resync base snapshot will be: Backup-ANA-SV_daily_20140406200000 Resync may alter the data in this qtree. Are you sure you want to resync the qtree? y Mon Apr 7 14:09:49 CEST [hana2b:replication.dst.resync.success:notice]: SnapVault resync of /vol/backup_data_00002/mnt00002 to hana1b:/vol/data_00002/mnt00002 was successful. Transfer started. Monitor progress with 'snapvault status' or the snapmirror log.
hana2b> snapvault start -r -S hana1a:/vol/data_00003/mnt00003 hana2b:/vol/backup_data_00003/mnt00003 The resync base snapshot will be: Backup-ANA-SV_daily_20140406200000 Resync may alter the data in this qtree. Are you sure you want to resync the qtree? y Mon Apr 7 14:10:25 CEST [hana2b:replication.dst.resync.success:notice]: SnapVault resync of /vol/backup_data_00003/mnt00003 to hana1a:/vol/data_00003/mnt00003 was successful. Transfer started. Monitor progress with 'snapvault status' or the snapmirror log.
When the data transfer is finished, you can again schedule backups by using Snap Creator.
