Configuring settings for the Domino plug-in
You need to configure specific settings only if you plan to use the IBM Domino plug-in, which is included as part of the Snap Creator Agent installation.
It is a best practice to install Snap Creator Server and Snap Creator Agent on different hosts. |
Depending on your operating system, you must configure these settings before installing the Snap Creator Agent for the IBM Domino plug-in to work properly.
For a Windows environment, you must add the Domino path to the environment variables.
For a UNIX environment, you must create symbolic links to link to Domino's shared object files.
