Snap Creator Framework
Starting the SnapVault relationships with Data ONTAP operating in 7-Mode
Contributors netapp-aherbin
You can start a SnapVault relationship with commands executed on the secondary storage system.
  1. For storage systems running Data ONTAP operating in 7-Mode, you start the SnapVault relationships by running the following command:
    hana2b> snapvault start -S hana1a:/vol/data_00001/mnt00001 /vol/backup_data_00001/mnt00001
    Snapvault configuration for the qtree has been set.
    Transfer started.
    Monitor progress with 'snapvault status' or the snapmirror log.
    hana2b>
    hana2b> snapvault start -S hana1a:/vol/data_00003/mnt00003 /vol/backup_data_00003/mnt00003
    Transfer started.
    hana2b>
    hana2b> snapvault start -S hana1b:/vol/data_00002/mnt00002 /vol/backup_data_00002/mnt00002
    Transfer started.
    hana2b>
    Note It is recommended that you use a dedicated network for replication traffic. In that case, configure the host name of this interface at the primary storage controllers. Instead of hana1b and hana1a, the host name could be hana1a-rep and hana1b-rep.
