Creating symbolic links for the Domino plug-in on AIX hosts
You must perform this procedure to add symbolic links for the Domino plug-in on AIX hosts.
You should not copy and paste commands directly from this document; errors (such as incorrectly transferred characters caused by line breaks and hard returns) might result. Copy and paste the commands into a text editor, verify the commands, and then enter them in the CLI console.
The paths provided in the following steps refer to the 32-bit systems; 64-bit systems must create simlinks to /usr/lib64 instead of /usr/lib. |
Add links to /usr/lib for the following files:
libxmlproc_r.a
libndgts_r.a
libnotes_r.a
libgsk8iccs_r.a (for Domino 9.0 or later only) A typical method of creating a symbolic link is to use the ln command:
ln -s /path/to/source_file /usr/lib/linked_file
+ where:
-s instructs the operating system to make a symbolic link.
/path/to/source_file is the path to one of the Domino library files, including the file name.
linked_file is the name of the file that is being linked.
ln -s /opt/ibm/domino/notes/latest/ibmpow/libxmlproc_r.a /usr/lib/libxmlproc_r.a ln -s /opt/ibm/domino/notes/latest/ibmpow/libndgts_r.a /usr/lib/libndgts_r.a ln -s /opt/ibm/domino/notes/latest/ibmpow/libnotes_r.a /usr/lib/libnotes_r.a ln -s /opt/ibm/domino/notes/latest/linux/libgsk8iccs.so /usr/lib/libgsk8iccs_r.a
Verify the path to the files listed in Step 1.
The commands in this example use the default path for AIX, but installations can vary.
