Creating symbolic links for the Domino plug-in on Linux and Solaris hosts
You need to perform this procedure if you want to create symbolic links for the Domino plug-in on Linux and Solaris hosts.
You should not copy and paste commands directly from this document; errors (such as incorrectly transferred characters caused by line breaks and hard returns) might result. Copy and paste the commands into a text editor, verify the commands, and then enter them in the CLI console.
The paths provided in the following steps refer to the 32-bit systems; 64-bit systems must create simlinks to /usr/lib64 instead of /usr/lib. |
Add links to /usr/lib for the following files:
libxmlproc.so
libndgts.so
libnotes.so
libgsk8iccs.so (for Domino 9.0 or later only) A typical method of creating a symbolic link is to use the ln command:
ln -s /path/to/source_file /usr/lib/linked_file
+ where:
-s instructs the operating system to make a symbolic link.
/path/to/source_file is the path to one of the Domino library files, including the file name.
linked_file is the name of the file that is being linked.
ln -s /opt/ibm/domino/notes/latest/linux/libxmlproc.so /usr/lib/libxmlproc.so ln -s /opt/ibm/domino/notes/latest/linux/libndgts.so /usr/lib/libndgts.so ln -s /opt/ibm/domino/notes/latest/linux/libnotes.so /usr/lib/libnotes.so ln -s /opt/ibm/domino/notes/latest/linux/libgsk8iccs.so /usr/lib/libgsk8iccs.so
Verify the path to the files listed in Step 1.
