Cloud Volumes ONTAP
All cloud providers
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Optimize your Cloud Volumes ONTAP systems using Digital Advisor
Contributors netapp-bcammett netapp-manini netapp-dbagwell netapp-rlithman
Active IQ Digital Advisor (also known as Digital Advisor) is integrated into the BlueXP UI so that you can optimize the operations, security, and performance of your Cloud Volumes ONTAP systems in a single pane of glass.
Features
You can view the overall status of your storage system, high-level information about the wellness of the system, inventory, planning, and valuable insights at a watchlist level using Digital Advisor.
  • Analyze and optimize the health of your storage systems
  • Gain insights regarding all the risks to your storage systems and the actions to mitigate the risks
  • Analyze the performance of your storage devices by viewing the graphical format of performance data
  • Get details about systems that have exceeded 90% capacity or are nearing 90% capacity
Supported ONTAP systems
Digital Advisor provides information for all the on-premises ONTAP systems and Cloud Volumes ONTAP systems within your NSS account.
Cost
There's no cost to use this service through BlueXP.
How Digital Advisor works with BlueXP
The Digital Advisor user interface is completely integrated in BlueXP.
In BlueXP, click the Digital Advisor service.
Note As of December 3, 2021, NetApp has switched to a new methodology of registering credentials for NSS accounts. For more information, refer to this FAQ. If your NSS account uses the old set of credentials you will need to update the account to the new credentials.
What's next
Refer to the Digital Advisor documentation for details.
