List all LDAP users
GET /accounts/{account_id}/core/v1/ldapUsers
Returns a JSON array of JSON objects containing the results of the request URL.
Name | Type | In | Required | Description |
account_id |
string |
path |
True |
include |
string |
query |
False |
Indicates which fields should be returned when listing a collection. URL examples: "include=id", "include=id,name" OpenAPI examples: "id"
limit |
string |
query |
False |
Indicates the maximum number of resources to return when listing a collection. URL examples: "limit=2" OpenAPI examples: "2" |
filter |
string |
query |
False |
Indicates which fields should be matched in order to return a resource when listing a collection. Supported operators are:
URL example: "filter=field%20eq%20%27value%27" OpenAPI examples: "field eq 'value'" |
continue |
query |
False |
Indicates the token to resume listing from. URL examples: "continue= OpenAPI examples: " |
Status: 200, Returns a JSON array of JSON objects containing the results of the request URL.
Name | Type | Required | Description |
items |
array[Any of: ldapUser_1.0_get_response_body, array[]] |
True |
metadata |
True |
"type": "application/astra-ldapUsers",
"version": "1.0",
"items": [
"b4bcef18-14ad-5bc1-91ce-3cce15aa8791",
"John Doe",
"cn=John Doe,ou=people,dc=example,dc=com"
"98b10d6f-8693-555f-b258-70de4cc7301f",
"Jane Doe",
"cn=Jane Doe,ou=people,dc=example,dc=com"
"metadata": {
"labels": [],
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/14",
"title": "Unauthorized access",
"detail": "The user isn't enabled.",
"status": "403"
Status: 406, Not acceptable
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/32",
"title": "Unsupported content type",
"detail": "The response can't be returned in the requested format.",
"status": "406"
Status: 500, Internal server error
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/34",
"title": "Internal server error",
"detail": "The server was unable to process this request.",
"status": "500"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
Example error response
"status": "400"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
type |
string |
True |
version |
string |
True |
id |
string |
True |
string |
False |
JSON string representing the email of the LDAP user. Defined values are:
firstName |
string |
False |
JSON string representing the first name of the LDAP user. Defined values are:
lastName |
string |
False |
JSON string representing the last name of the LDAP user. Defined values are:
cn |
string |
False |
JSON string representing the LDAP group name. Defined values are:
dn |
string |
False |
JSON string representing the distinguished name of the LDAP group. Defined values are:
metadata |
True |
type_astra_metadata_list
continue |
string |
False |
count |
number |
False |
labels |
False |
creationTimestamp |
string |
False |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
