Load the saved criteria
From the home page, you can choose to either search for components or load the previously saved criteria.
Before you begin
You must have saved the search criteria on the home page.
About this task
You can click Saved Search to load all of the criteria that you saved earlier.
Steps
Click Saved Search on the first page.
Click Criteria or Configuration tab to load the saved criteria or configuration. After you select the criteria name, the criteria will load in the search criteria panel.
