Subscribe to Storage Solutions
You can subscribe to single or multiple storage solutions of your choice.
About this task
The two types of subscription are as follows:
  1. Immediate: You will receive an email immediately when there are any changes made to the subscribed solution.
  2. Digest: You will receive an accumulated email within seven days reflecting all the changes that are made to the subscribed solutions.
Steps
  1. Click the Subscription link from the header menu.
  2. In the Subscription window, select the Storage Solution tab.
  3. For storage solutions of your choice, select checkboxes for the Solution status update, Categories associated or disassociated, or Configurations added or deleted options.
    You will receive emails for the following instances:
    • When the status of the solutions is changed or updated.
    • When some categories are added or deleted from the solution
    • When some configurations are added or deleted from the solution
  4. In the Frequency field, either select Immediate or Digest.
    Note The default selection is Immediate.
  5. Click Subscribe to subscribe for solutions that you have selected.
    Note You can click Reset to clear all of the selections in the Storage Solution tab.
