Work with List and Find
In the List and Find component work area you can view the best possible configurations for your components.
About this task
Use the Component Explorer panel on the left to view configurations for selected components. The panel on the right displays the solutions; each tab represents a storage solution and the number of configurations that use the selected components. If the green Logic toggle button on the List and Find Component Workarea is set to OR, you can search for solutions that have configurations containing single components. If the green Logic toggle button is set to AND, you can search for solutions that have configurations containing all the selected components. If multiple components are selected within the same component type, the button is set to OR.
Steps
  1. Click List and Find on the home page.
  2. Search for a component name in the Component Explorer or expand the selection to add components to the List and Find Component Workarea.
    Note You can select specific enabled solutions after adding a component to the List and Find Component Workarea before clicking Next. You can also export a maximum of 3000 rows for one solution at a time in an Excel spreadsheet or PDF.
  3. Click Next to view where the components are used in configurations across multiple solutions on the Results page. The most compatible configuration for your list of components is displayed.
