Save configuration
You can save configurations with any name of your choice for a particular solution. This helps you to retrieve the configurations later without remembering the complicated configuration ID.
Before you begin
You can easily retrieve the desired configuration later by looking for the name that you had specified.
About this task
If you want to refer to the configuration later, you can save the configuration with any name of your choice.
Steps
  1. In the Results page, click star to save the configuration. After you save the configuration, the star turns yellow. You can save a maximum of 20 configurations.
  2. In the Tag Configuration dialog box, enter the name and description to bookmark the configuration for reference. The saved configuration name is displayed on the configuration details link. You can add multiple configurations to a particular tag. A tag is unique to a single solution. Different users can use the same tag name.
  3. Select the tag name from the drop-down arrow to add configurations to an already saved tab.
