Understand and use Interoperability Matrix Tool results
Interoperability Matrix Tool allows you to view and export the results for the configurations that meet your requirements. From the Results page, you can build an end-to-end view by choosing a related solution which is compatible with the selected configuration. Additionally, you can use the What If feature to upgrade or downgrade a component within a configuration.
