Subscribe to Components
You can subscribe to single or multiple components of your choice.
About this task
You will receive an email notification when changes are made in the display name of the component or state of the component.
Steps
  1. Click the Subscription link from the header menu.
  2. In the subscription window, select the Component tab.
  3. To subscribe for the component of your choice, select the checkbox for the Attribute Updated option.
  4. In the Frequency field, select Immediate or Digest.
    Note The default selection is Immediate.
  5. Click Subscribe to get the subscriptions for the components that you have subscribed.
    Note You can click Reset to clear all of the selections in the Component tab.
