Work with preferences
The Preferences List and Find Category Preferences menu opens the List and Find Category Preferences page, where you can save your favorite categories to the top of the List and Find Component Explorer list.
About this task
You can use the List and Find Category Preferences page to select your favorite categories. These categories appear on the top of the List and Find Component Explorer list and are boxed in red.
Steps
  1. Click Preferences List and Find Category Preferences on the home page. The List and Find Category Preferences page opens.
  2. Select the categories you want to save as your favorites. You can scroll through the list or search for categories in the Search Categories field. You can select as many categories as you need.
  3. Click Save to keep your preferences. If needed, you can click Reset to clear the existing preferences list.
  4. To view your preferences, click Home and then click List and Find. Your favorite categories appear at the top of the Component Explorer, outlined in red.
