Saved search capabilities
You can load different solutions or configurations using the Saved Search menu, which enables you to navigate to previously saved search results, recent search results, and saved configurations.
The Search Criteria tab holds your saved searches. On this tab, you can share searches or view searches that others have shared with you. The Configuration tab holds your saved configurations. On this tab you can share configurations or view configurations that others have shared with you.
The Recent Search tab holds the last 30 sets of search criteria, from the most recent to the oldest. It also lists the Search Flow that indicates the originating page, which can be List and Find, Solution Explorer, or Advanced Search. The criteria is saved automatically. This page also lists the Last Modified Date of a saved or recent search. You can Load a search from the list to view the criteria or configurations respectively.
