ONTAP MetroCluster
NetApp-validated and MetroCluster-compliant switches
Contributors netapp-aoife
All of the switches used in your configuration, including backend switches, must either be NetApp-validated or MetroCluster-compliant.
NetApp-validated switches
A switch is NetApp-validated if it meets the following requirements:
  • The switch is provided by NetApp as part of the MetroCluster IP configuration
  • The switch is listed in the NetApp Hardware Universe as a supported switch under MetroCluster-over-IP-connections
  • The switch is only used to connect MetroCluster IP controllers and, in some configurations, NS224 drive shelves
  • The switch is configured using the Reference Configuration File (RCF) provided by NetApp
Any switch that does not meet these requirements is not a NetApp-validated switch.
A MetroCluster-compliant switch is not NetApp-validated but can be used in a MetroCluster IP configuration if it meets certain requirements and configuration guidelines.
Note NetApp does not provide troubleshooting or configuration support services for any non-validated MetroCluster-compliant switch.
