Powering up both controller modules and displaying the LOADER prompt
PDF of this doc site
- Install a fabric-attached MetroCluster
- Install a MetroCluster IP configuration
- Install a stretch MetroCluster configuration
- Transition from MetroCluster FC to MetroCluster IP
Creating your file...
You power up the existing controller module and the new controller module to display the LOADER prompt.
Power up the controller modules and interrupt the boot process, using the steps for your configuration:
If the controller modules are… |
Then… |
In the same chassis |
In separate chassis |
Each controller module should display the LOADER prompt (LOADER>
, LOADER-A>
, or LOADER-B>
If there is no LOADER prompt, record the error message. If the system displays the boot menu, reboot and attempt to interrupt the boot process again. |
