ONTAP MetroCluster
Configure end-to-end encryption in a MetroCluster IP configuration
Contributors netapp-aoife
Beginning with ONTAP 9.15.1, you can configure end-to-end encryption to encrypt back-end traffic, such as NVlog and storage replication data, between the sites in a MetroCluster IP configuration.
About this task
  • You must be a cluster administrator to perform this task.
  • Before you can configure end-to-end encryption, you must Configure external key management.
  • Review the supported systems and minimum ONTAP release required to configure end-to-end encryption in a MetroCluster IP configuration:
    Minimum ONTAP release
    Supported systems
    ONTAP 9.15.1
    • AFF A400
    • FAS8300
    • FAS8700
Enable end-to-end encryption
Perform the following steps to enable end-to-end encryption.
Steps
  1. Verify the health of the MetroCluster configuration.
    1. Verify that the MetroCluster components are healthy:
      metrocluster check run
      cluster_A::*> metrocluster check run
      The operation runs in the background.
    2. After the metrocluster check run operation completes, run:
      metrocluster check show
      After approximately five minutes, the following results are displayed:
      cluster_A:::*> metrocluster check show
      Component           Result
      nodes               ok
      lifs                ok
      config-replication  ok
      aggregates          ok
      clusters            ok
      connections         not-applicable
      volumes             ok
      7 entries were displayed.
    3. Check the status of the running MetroCluster check operation:
      metrocluster operation history show -job-id <id>
    4. Verify that there are no health alerts:
      system health alert show
  2. Verify that external key management is configured on both clusters:
    security key-manager external show-status
  3. Enable end-to-end encryption for each DR group:
    metrocluster modify -is-encryption-enabled true -dr-group-id <dr_group_id>
    Example
    cluster_A::*> metrocluster modify -is-encryption-enabled true -dr-group-id 1
    Warning: Enabling encryption for a DR Group will secure NVLog and Storage
             replication data sent between MetroCluster nodes and have an impact on
             performance. Do you want to continue? {y|n}: y
    [Job 244] Job succeeded: Modify is successful.
    Repeat this step for each DR group in the configuration.
  4. Verify that end-to-end encryption is enabled:
    metrocluster node show -fields is-encryption-enabled
    Example
    cluster_A::*> metrocluster node show -fields is-encryption-enabled
    dr-group-id cluster    node      configuration-state is-encryption-enabled
    1           cluster_A  node_A_1  configured          true
    1           cluster_A  node_A_2  configured          true
    1           cluster_B  node_B_1  configured          true
    1           cluster_B  node_B_2  configured          true
    4 entries were displayed.
Disable end-to-end encryption
Perform the following steps to disable end-to-end encryption.
Steps
      Component           Result
      nodes               ok
      lifs                ok
      aggregates          ok
      clusters            ok
      volumes             ok
  3. Disable end-to-end encryption on each DR group:
    metrocluster modify -is-encryption-enabled false -dr-group-id <dr_group_id>
    Example
    cluster_A::*> metrocluster modify -is-encryption-enabled false -dr-group-id 1
  4. Verify that end-to-end encryption is disabled:
    Example
    1           cluster_A  node_A_1  configured          false
    1           cluster_A  node_A_2  configured          false
    1           cluster_B  node_B_1  configured          false
    1           cluster_B  node_B_2  configured          false
