ONTAP MetroCluster
Port assignments for FC switches when using ONTAP 9.1 or later
Contributors netapp-martyh netapp-aoife netapp-thomi
You need to verify that you are using the specified port assignments when you cable the FC switches using ONTAP 9.1 and later.
Ports that are not used for attaching initiator ports, FC-VI ports, or ISLs can be reconfigured to act as storage ports. However, if the supported RCFs are being used, the zoning must be changed accordingly.
If the supported RCFs are used, ISL ports might not connect to the same ports shown and might need to be reconfigured manually.
If you configured your switches using the port assignments for ONTAP 9, you can continue to use the older assignments. However, new configurations running ONTAP 9.1 or later releases should use the port assignments shown here.
Overall cabling guidelines
You should be aware of the following guidelines when using the cabling tables:
  • The Brocade and Cisco switches use different port numbering:
    • On Brocade switches, the first port is numbered 0.
    • On Cisco switches, the first port is numbered 1.
  • The cabling is the same for each FC switch in the switch fabric.
  • AFF A300 and FAS8200 storage systems can be ordered with one of two options for FC-VI connectivity:
    • Onboard ports 0e and 0f configured in FC-VI mode.
    • Ports 1a and 1b on an FC-VI card in slot 1.
  • AFF A700 and FAS9000 storage systems require four FC-VI ports. The following tables show cabling for the FC switches with four FC-VI ports on each controller except for the Cisco 9250i switch.
    For other storage systems, use the cabling shown in the tables but ignore the cabling for FC-VI ports c and d.
    You can leave those ports empty.
  • AFF A400 and FAS8300 storage systems use ports 2a and 2b for FC-VI connectivity.
  • If you have two MetroCluster configurations sharing ISLs, use the same port assignments as that for an eight-node MetroCluster cabling.
    The number of ISLs you cable may vary depending on site's requirements.
    See the section on ISL considerations.
Brocade port usage for controllers in a MetroCluster configuration running ONTAP 9.1 or later
The following tables show port usage on Brocade switches. The tables show the maximum supported configuration, with eight controller modules in two DR groups. For smaller configurations, ignore the rows for the additional controller modules. Note that eight ISLs are supported only on the Brocade 6510, Brocade DCX 8510-8, G620, G630, G620-1, G630-1, and G720 switches.
Note
  • Port usage for the Brocade 6505 and Brocade G610 switches in an eight-node MetroCluster configuration is not shown. Due to the limited number of ports, port assignments must be made on a site-by-site basis depending on the controller module model and the number of ISLs and bridge pairs in use.
  • The Brocade DCX 8510-8 switch can use the same port layout as the 6510 switch or the 7840 switch.
Configurations using FibreBridge 7500N or 7600N using one FC port (FC1 or FC2) only
MetroCluster 1 or DR Group 1
Component
Port
Brocade switch models 6505, 6510, 6520, 7810, 7840, G610, G620, G620-1, G630, G630-1 and DCX 8510-8
Brocade switch model G720
Connects to FC switch…​
Connects to switch port…​
controller_x_1
FC-VI port a
1
0
0
FC-VI port b
2
0
0
FC-VI port c
1
1
1
FC-VI port d
2
1
1
HBA port a
1
2
8
HBA port b
2
2
8
HBA port c
1
3
9
HBA port d
2
3
9
controller_x_2
FC-VI port a
1
4
4
FC-VI port b
2
4
4
FC-VI port c
1
5
5
FC-VI port d
2
5
5
HBA port a
1
6
12
HBA port b
2
6
12
HBA port c
1
7
13
HBA port d
2
7
13
Component
Port
Stack 1
bridge_x_1a
1
8
10
bridge_x_1b
2
8
10
Stack 2
bridge_x_2a
1
9
11
bridge_x_2b
2
9
11
Stack 3
bridge_x_3a
1
10
14
bridge_x_4b
2
10
14
Stack y
bridge_x_ya
1
11
15
bridge_x_yb
2
11
15
Note
  • On G620, G630, G620-1 and G630-1 switches, additional bridges can be cabled to ports 12 - 17, 20 and 21.
  • On G610 switches, additional bridges can be cabled to ports 12 - 19.
  • On G720 switches, additional bridges can be cabled to ports 16 - 17, 20 and 21.
MetroCluster 2 or DR Group 2
Component
Port
Connects to FC_switch…​
6510, DCX 8510-8
6520
7840, DCX 8510-8
G720
controller_x_3
FC-VI port a
1
24
48
12
18
18
FC-VI port b
2
24
48
12
18
18
FC-VI port c
1
25
49
13
19
19
FC-VI port d
2
25
49
13
19
19
HBA port a
1
26
50
14
24
26
HBA port b
2
26
50
14
24
26
HBA port c
1
27
51
15
25
27
HBA port d
2
27
51
15
25
27
controller_x_4
FC-VI port a
1
28
52
16
22
22
FC-VI port b
2
28
52
16
22
22
FC-VI port c
1
29
53
17
23
23
FC-VI port d
2
29
53
17
23
23
HBA port a
1
30
54
18
28
30
HBA port b
2
30
54
18
28
30
HBA port c
1
31
55
19
29
31
HBA port d
2
32
55
19
29
31
Stack 1
bridge_x_51a
1
32
56
20
26
32
bridge_x_51b
2
32
56
20
26
32
Stack 2
bridge_x_52a
1
33
57
21
27
33
bridge_x_52b
2
33
57
21
27
33
Stack 3
bridge_x_53a
1
34
58
22
30
34
bridge_x_54b
2
34
58
22
30
34
Stack y
bridge_x_ya
1
35
59
23
31
35
bridge_x_yb
2
35
59
23
31
35
Note
  • On G720 switches, additional bridges can be cabled to ports 36-39.
Configurations using FibreBridge 7500N or 7600N using both FC ports (FC1 and FC2)
Component
Port
Brocade switch models 6505, 6510, 6520, 7810, 7840, G610, G620, G620-1, G630, G630-1, and DCX 8510-8
Brocade switch G720
Stack 1
bridge_x_1a
FC1
1
8
10
FC2
2
8
10
bridge_x_1B
FC1
1
9
11
FC2
2
9
11
Stack 2
bridge_x_2a
FC1
1
10
14
FC2
2
10
14
bridge_x_2B
FC1
1
11
15
FC2
2
11
15
Stack 3
bridge_x_3a
FC1
1
12*
16
FC2
2
12*
16
bridge_x_3B
FC1
1
13*
17
FC2
2
13*
17
Stack y
bridge_x_ya
FC1
1
14*
20
FC2
2
14*
20
bridge_x_yb
FC1
1
15*
21
FC2
2
15*
21
* Ports 12 through 15 are reserved for the second MetroCluster or DR group on the Brocade 7840 switch.
Note Additional bridges can be cabled to ports 16, 17, 20 and 21 in G620, G630, G620-1 and G630-1 switches.
Component
Port
6510, DCX 8510-8
6520
7840, DCX 8510-8
G720
controller_x_3
FC-VI port a
1
24
48
12
18
18
FC-VI port b
2
24
48
12
18
18
FC-VI port c
1
25
49
13
19
19
FC-VI port d
2
25
49
13
19
19
HBA port a
1
26
50
14
24
26
HBA port b
2
26
50
14
24
26
HBA port c
1
27
51
15
25
27
HBA port d
2
27
51
15
25
27
controller_x_4
FC-VI port a
1
28
52
16
22
22
FC-VI port b
2
28
52
16
22
22
FC-VI port c
1
29
53
17
23
23
FC-VI port d
2
29
53
17
23
23
HBA port a
1
30
54
18
28
30
HBA port b
2
30
54
18
28
30
HBA port c
1
31
55
19
29
31
HBA port d
2
31
55
19
29
31
Stack 1
bridge_x_51a
FC1
1
32
56
20
26
32
FC2
2
32
56
20
26
32
bridge_x_51b
FC1
1
33
57
21
27
33
FC2
2
33
57
21
27
33
Stack 2
bridge_x_52a
FC1
1
34
58
22
30
34
FC2
2
34
58
22
30
34
bridge_x_52b
FC1
1
35
59
23
31
35
FC2
2
35
59
23
31
35
Stack 3
bridge_x_53a
FC1
1
36
60
32
36
FC2
2
36
60
32
36
bridge_x_53b
FC1
1
37
61
33
37
FC2
2
37
61
33
37
Stack y
bridge_x_5ya
FC1
1
38
62
34
38
FC2
2
38
62
34
38
bridge_x_5yb
FC1
1
39
63
35
39
FC2
2
39
63
35
39
Note Additional bridges can be cabled to ports 36 to 39 in G620, G630, G620-1, and G630-1 switches.
Brocade port usage for ISLs in a MetroCluster configuration running ONTAP 9.1 or later
The following table shows ISL port usage for the Brocade switches.
Note AFF A700 or FAS9000 systems support up to eight ISLs for improved performance. Eight ISLs are supported on the Brocade 6510 and G620 switches.
Switch model
ISL port
Switch port
Brocade 6520
ISL port 1
23
ISL port 2
47
ISL port 3
71
ISL port 4
95
Brocade 6505
ISL port 1
20
ISL port 2
21
ISL port 3
22
ISL port 4
23
Brocade 6510 and Brocade DCX 8510-8
ISL port 1
40
ISL port 2
41
ISL port 3
42
ISL port 4
43
ISL port 5
44
ISL port 6
45
ISL port 7
46
ISL port 8
47
Brocade 7810
ISL port 1
ge2 (10-Gbps)
ISL port 2
ge3(10-Gbps)
ISL port 3
ge4 (10-Gbps)
ISL port 4
ge5 (10-Gbps)
ISL port 5
ge6 (10-Gbps)
ISL port 6
ge7 (10-Gbps)
Brocade 7840
Note: The Brocade 7840 switch supports either two 40 Gbps VE-ports or up to four 10 Gbps VE-ports per switch for the creation of FCIP ISLs.
ISL port 1
ge0 (40-Gbps) or ge2 (10-Gbps)
ISL port 2
ge1 (40-Gbps) or ge3 (10-Gbps)
ISL port 3
ge10 (10-Gbps)
ISL port 4
ge11 (10-Gbps)
Brocade G610
ISL port 1
20
ISL port 2
21
ISL port 3
22
ISL port 4
23
Brocade G620, G620-1, G630, G630-1, G720
ISL port 1
40
ISL port 2
41
ISL port 3
42
ISL port 4
43
ISL port 5
44
ISL port 6
45
ISL port 7
46
ISL port 8
47
Cisco port usage for controllers in a MetroCluster configuration running ONTAP 9.4 or later
The tables show the maximum supported configurations, with eight controller modules in two DR groups. For smaller configurations, ignore the rows for the additional controller modules.
Cisco 9396S
Component
Port
Switch 1
Switch 2
controller_x_1
FC-VI port a
1
FC-VI port b
1
FC-VI port c
2
FC-VI port d
2
HBA port a
3
HBA port b
3
HBA port c
4
HBA port d
4
controller_x_2
FC-VI port a
5
FC-VI port b
5
FC-VI port c
6
FC-VI port d
6
HBA port a
7
HBA port b
7
HBA port c
8
HBA port d
8
controller_x_3
FC-VI port a
49
FC-VI port b
49
FC-VI port c
50
FC-VI port d
50
HBA port a
51
HBA port b
51
HBA port c
52
HBA port d
52
controller_x_4
FC-VI port a
53
FC-VI port b
53
FC-VI port c
54
FC-VI port d
54
HBA port a
55
HBA port b
55
HBA port c
56
HBA port d
56
Cisco 9148S
Component
Port
Switch 1
Switch 2
controller_x_1
FC-VI port a
1
FC-VI port b
1
FC-VI port c
2
FC-VI port d
2
HBA port a
3
HBA port b
3
HBA port c
4
HBA port d
4
controller_x_2
FC-VI port a
5
FC-VI port b
5
FC-VI port c
6
FC-VI port d
6
HBA port a
7
HBA port b
7
HBA port c
8
HBA port d
8
controller_x_3
FC-VI port a
25
FC-VI port b
25
FC-VI port c
26
FC-VI port d
26
HBA port a
27
HBA port b
27
HBA port c
28
HBA port d
28
controller_x_4
FC-VI port a
29
FC-VI port b
29
FC-VI port c
30
FC-VI port d
30
HBA port a
31
HBA port b
31
HBA port c
32
HBA port d
32
Note The following table shows systems with two FC-VI ports. AFF A700 and FAS9000 systems have four FC-VI ports (a, b, c, and d). If using an AFF A700 or FAS9000 system, the port assignments move along by one position. For example, FC-VI ports c and d go to switch port 2 and HBA ports a and b go to switch port 3.
Cisco 9250i
Note: The Cisco 9250i switch is not supported for eight-node MetroCluster configurations.
Component
Port
Switch 1
Switch 2
controller_x_1
FC-VI port a
1
FC-VI port b
1
HBA port a
2
HBA port b
2
HBA port c
3
HBA port d
3
controller_x_2
FC-VI port a
4
FC-VI port b
4
HBA port a
5
HBA port b
5
HBA port c
6
HBA port d
6
controller_x_3
FC-VI port a
7
FC-VI port b
7
HBA port a
8
HBA port b
8
HBA port c
9
HBA port d
9
controller_x_4
FC-VI port a
10
FC-VI port b
10
HBA port a
11
HBA port b
11
HBA port c
13
HBA port d
13
Cisco port usage for FC-to-SAS bridges in a MetroCluster configuration running ONTAP 9.1 or later
Cisco 9396S
FibreBridge 7500N or 7600N using two FC ports
Port
Switch 1
Switch 2
bridge_x_1a
FC1
9
FC2
9
bridge_x_1b
FC1
10
FC2
10
bridge_x_2a
FC1
11
FC2
11
bridge_x_2b
FC1
12
FC2
12
bridge_x_3a
FC1
13
FC2
13
bridge_x_3b
FC1
14
FC2
14
bridge_x_4a
FC1
15
FC2
15
bridge_x_4b
FC1
16
FC2
16
Additional bridges can be attached using ports 17 through 40 and 57 through 88 following the same pattern.
Cisco 9148S
Port
Switch 1
Switch 2
bridge_x_1a
FC1
9
FC2
9
bridge_x_1b
FC1
10
FC2
10
bridge_x_2a
FC1
11
FC2
11
bridge_x_2b
FC1
12
FC2
12
bridge_x_3a
FC1
13
FC2
13
bridge_x_3b
FC1
14
FC2
14
bridge_x_4a
FC1
15
FC2
15
bridge_x_4b
FC1
16
FC2
16
Additional bridges for a second DR group or second MetroCluster configuration can be attached using ports 33 through 40 following the same pattern.
Cisco 9250i
Port
Switch 1
Switch 2
bridge_x_1a
FC1
14
FC2
14
bridge_x_1b
FC1
15
FC2
15
bridge_x_2a
FC1
17
FC2
17
bridge_x_2b
FC1
18
FC2
18
bridge_x_3a
FC1
19
FC2
19
bridge_x_3b
FC1
21
FC2
21
bridge_x_4a
FC1
22
FC2
22
bridge_x_4b
FC1
23
FC2
23
Additional bridges for a second DR group or second MetroCluster configuration can be attached using ports 25 through 48 following the same pattern.
The following tables show bridge port usage when using FibreBridge 7500N or 7600N bridges using one FC port (FC1 or FC2) only. For FibreBridge 7500N or 7600N bridges using one FC port, either FC1 or FC2 can be cabled to the port indicated as FC1. Additional bridges can be attached using ports 25-48.
Port
Cisco 9396S
Switch 1
Switch 2
bridge_x_1a
FC1
9
bridge_x_1b
FC1
9
bridge_x_2a
FC1
10
bridge_x_2b
FC1
10
bridge_x_3a
FC1
11
bridge_x_3b
FC1
11
bridge_x_4a
FC1
12
bridge_x_4b
FC1
12
bridge_x_5a
FC1
13
bridge_x_5b
FC1
13
bridge_x_6a
FC1
14
bridge_x_6b
FC1
14
bridge_x_7a
FC1
15
bridge_x_7b
FC1
15
bridge_x_8a
FC1
16
bridge_x_8b
FC1
16
Bridge
Port
Cisco 9148S
Switch 1
Switch 2
bridge_x_1a
FC1
9
bridge_x_1b
FC1
9
bridge_x_2a
FC1
10
bridge_x_2b
FC1
10
bridge_x_3a
FC1
11
bridge_x_3b
FC1
11
bridge_x_4a
FC1
12
bridge_x_4b
FC1
12
bridge_x_5a
FC1
13
bridge_x_5b
FC1
13
bridge_x_6a
FC1
14
bridge_x_6b
FC1
14
bridge_x_7a
FC1
15
bridge_x_7b
FC1
15
bridge_x_8a
FC1
16
bridge_x_8b
FC1
16
Cisco 9250i
Port
Switch 1
Switch 2
bridge_x_1a
FC1
14
bridge_x_1b
FC1
14
bridge_x_2a
FC1
15
bridge_x_2b
FC1
15
bridge_x_3a
FC1
17
bridge_x_3b
FC1
17
bridge_x_4a
FC1
18
bridge_x_4b
FC1
18
bridge_x_5a
FC1
19
bridge_x_5b
FC1
19
bridge_x_6a
FC1
21
bridge_x_6b
FC1
21
bridge_x_7a
FC1
22
bridge_x_7b
FC1
22
bridge_x_8a
FC1
23
bridge_x_8b
FC1
23
Additional bridges can be attached using ports 25 through 48 following the same pattern.
Cisco port usage for ISLs in an eight-node configuration in a MetroCluster configuration running ONTAP 9.1 or later
The following table shows ISL port usage. ISL port usage is the same on all switches in the configuration.
Switch model
ISL port
Switch port
Cisco 9396S
ISL 1
44
ISL 2
48
ISL 3
92
ISL 4
96
Cisco 9250i with 24 port license
ISL 1
12
ISL 2
16
ISL 3
20
ISL 4
24
Cisco 9148S
ISL 1
20
ISL 2
24
ISL 3
44
ISL 4
48
Cisco 9132T port usage in MetroCluster four-node and eight-node configurations running ONTAP 9.4 and later
The following table shows the port usage on a Cisco 9132T switch. The table shows the maximum supported configurations with four and eight controller modules in two DR groups.
Note For eight-node configurations, you must perform the zoning manually because RCFs are not provided.
Four-node
Eight-node
Component
Port
9132T (1x LEM)
9132T (2x LEM)
9132T (2x LEM)
controller_x_1
FC-VI port a
1
LEM1-1
LEM1-1
LEM1-1
FC-VI port b
2
LEM1-1
LEM1-1
LEM1-1
FC-VI port c
1
LEM1-2
LEM1-2
LEM1-2
FC-VI port d
2
LEM1-2
LEM1-2
LEM1-2
HBA port a
1
LEM1-5
LEM1-5
LEM1-3
HBA port b
2
LEM1-5
LEM1-5
LEM1-3
HBA port c
1
LEM1-6
LEM1-6
LEM1-4
HBA port d
2
LEM1-6
LEM1-6
LEM1-4
controller_x_2
FC-VI port a
1
LEM1-7
LEM1-7
LEM1-5
FC-VI port b
2
LEM1-7
LEM1-7
LEM1-5
FC-VI port c
1
LEM1-8
LEM1-8
LEM1-6
FC-VI port d
2
LEM1-8
LEM1-8
LEM1-6
HBA port a
1
LEM1-11
LEM1-11
LEM1-7
HBA port b
2
LEM1-11
LEM1-11
LEM1-7
HBA port c
1
LEM1-12
LEM1-12
LEM1-8
HBA port d
2
LEM1-12
LEM1-12
LEM1-8
controller_x_3
FC-VI port a
1
LEM2-1
FC-VI port b
2
LEM2-1
FC-VI port c
1
LEM2-2
FC-VI port d
2
LEM2-2
HBA port a
1
LEM2-3
HBA port b
2
LEM2-3
HBA port c
1
LEM2-4
HBA port d
2
LEM2-4
controller_x_4
FC-VI-1 port a
1
LEM2-5
FC-VI-1 port b
2
LEM2-5
FC-VI-1 port c
1
LEM2-6
FC-VI-1 port d
2
LEM2-6
HBA port a
1
LEM2-7
HBA port b
2
LEM2-7
HBA port c
1
LEM2-8
HBA port d
2
LEM2-8
Four-node
Eight-node
FibreBridge 7500N using two FC ports
Port
9132T (1x LEM)
9132T (2x LEM)
9132T (2x LEM)
Stack 1
bridge_x_1a
FC1
1
LEM1-13
LEM1-13
LEM1-9
FC2
2
LEM1-13
LEM1-13
LEM1-9
bridge_x_1b
FC1
1
LEM1-14
LEM1-14
LEM1-10
FC2
2
LEM1-14
LEM1-14
LEM1-10
Stack 2
bridge_x_2a
FC1
1
LEM1-15
LEM1-11
FC2
2
LEM1-15
LEM1-11
bridge_x_2b
FC1
1
LEM1-16
LEM1-12
FC2
2
LEM1-16
LEM1-12
Stack 3
bridge_x_3a
FC1
1
LEM2-1
LEM2-9
FC2
2
LEM2-1
LEM2-9
bridge_x_3b
FC1
1
LEM2-2
LEM2-10
FC2
2
LEM2-2
LEM2-10
Stack y
bridge_x_ya
FC1
1
LEM2-3
LEM2-11
FC2
2
LEM2-3
LEM2-11
bridge_x_yb
FC1
1
LEM2-4
LEM2-12
FC2
2
LEM2-4
LEM2-12
Note
  • In four-node configurations, you can cable additional bridges to ports LEM2-5 through LEM2-8 in 9132T switches with 2x LEMs.
  • In eight-node configurations, you can cable additional bridges to ports LEM2-13 through LEM2-16 in 9132T switches with 2x LEMs.
  • Only one (1) bridge stack is supported using 9132T switches with 1x LEM Module.
Cisco 9132T port usage for ISLs in four and eight-node configurations in a MetroCluster configuration running ONTAP 9.1 or later
The following table shows ISL port usage for a Cisco 9132T switch.
Port
Four-node
Eight-node
9132T (1x LEM)
9132T (2x LEM)
9132T (2x LEM)
ISL1
LEM1-15
LEM2-9
LEM1-13
ISL2
LEM1-16
LEM2-10
LEM1-14
ISL3
LEM2-11
LEM1-15
ISL4
LEM2-12
LEM1-16
ISL5
LEM2-13
ISL6
LEM2-14
ISL7
LEM2-15
ISL8
LEM2-16
