ONTAP MetroCluster
Cabling the FC-VI and HBA ports in a four-node fabric-attached MetroCluster configuration with array LUNs
Contributors netapp-thomi
If you are setting up a four-node fabric-attached MetroCluster configuration with array LUNs, you must cable the FC-VI ports and the HBA ports to the switch ports.
About this task
Steps
  1. Cable the FC-VI ports from each controller to the ports on alternate FC switches.
    The following example shows the connections between the FC-VI ports and switch ports at Site A:
    four node mcc fc vi switch connections
  2. Perform the controller-to-switch cabling at both of the MetroCluster sites.
    You must ensure redundancy in connections from the controller to the switches. Therefore, for each controller at a site, you must ensure that both of the HBA ports in the same port pair are connected to alternate FC switches.
    The following example shows the connections between the HBA ports and switch ports at Site A:
    four node mcc hba switch connections
    The following table lists the connections between the HBA ports on controller_A_1 and the FC switch ports in the illustration:
    HBA ports
    Switch ports
    Port pair
    Port a
    FC_switch_A_1, Port 2
    Port d
    FC_switch_A_2, Port 3
    Port pair
    Port b
    FC_switch_A_2, Port 2
    Port c
    FC_switch_A_1, Port 3
    The following table lists the connections between the HBA ports on controller_A_2 and the FC switch ports in the illustration:
    HBA ports
    Switch ports
    Port pair
    Port a
    FC_switch_A_1, Port 5
    Port d
    FC_switch_A_2, Port 6
    Port pair
    Port b
    FC_switch_A_2, Port 5
    Port c
    FC_switch_A_1, Port 6
After you finish
You should cable the ISLs between the FC switches across the MetroCluster sites.
Related information
When you are connecting ONTAP systems to FC switches for setting up a MetroCluster configuration with array LUNs, you must connect FC-VI and HBA ports from each controller to specific switch ports.
