ONTAP MetroCluster
Change the vendor or model of an FC switch
Contributors netapp-aoife
You might need to to change the vendor of an FC switch from Cisco to Brocade or vice versa, change the switch model, or change both.
About this task
  • This procedure applies when you are using NetApp validated switches.
  • You must perform the steps in this procedure on one Fabric at a time, for both Fabrics in the configuration.
Steps
  1. Check the health of the configuration.
    1. Check that the MetroCluster is configured and in normal mode on each cluster: metrocluster show
      cluster_A::> metrocluster show
      Cluster                   Entry Name          State
       Local: cluster_A         Configuration state configured
                                Mode                normal
                                AUSO Failure Domain auso-on-cluster-disaster
      Remote: cluster_B         Configuration state configured
                                Mode                normal
    2. Check that mirroring is enabled on each node: metrocluster node show
      cluster_A::> metrocluster node show
      DR                           Configuration  DR
      Group Cluster Node           State          Mirroring Mode
      1     cluster_A
                    node_A_1       configured     enabled   normal
            cluster_B
                    node_B_1       configured     enabled   normal
      2 entries were displayed.
    3. Check that the MetroCluster components are healthy: metrocluster check run
      cluster_A::> metrocluster check run
      Last Checked On: 10/1/2014 16:03:37
      Component           Result
      nodes               ok
      lifs                ok
      config-replication  ok
      aggregates          ok
      4 entries were displayed.
      Command completed. Use the "metrocluster check show -instance" command or sub-commands in "metrocluster check" directory for detailed results.
      To check if the nodes are ready to do a switchover or switchback operation, run "metrocluster switchover -simulate" or "metrocluster switchback -simulate", respectively.
    4. Check that there are no health alerts: system health alert show
  2. Configure the new switch before installation.
    Follow the steps in Configure the FC switches.
  3. Disconnect the connections from the old switch by removing the connections in the following order:
    1. If the local cluster interfaces are connected to a switch:
      1. Disconnect the local cluster interfaces
      2. Disconnect the local cluster ISLs
    2. Disconnect the MetroCluster FC interfaces.
    3. Disconnect the MetroCluster ISLs.
  4. Power off the old switch, remove the cables, and physically replace the old switch with the new switch.
  5. Cable the switches in the following order:
    You must follow the steps in Install and cable the MetroCluster components.
    1. Cable the ISLs to the remote site.
    2. Cable the MetroCluster FC interfaces.
    3. Cable the local cluster interfaces.
      1. Cable the local cluster interfaces.
      2. Cable the local cluster ISLs.
  6. Power up the switch.
  7. Verify that the MetroCluster configuration is healthy by repeating Step 1.
  8. Repeat Step 1 to Step 7 for the second Fabric in the configuration.
