Restoring Tiebreaker or Mediator monitoring
PDF of this doc site
- Install a fabric-attached MetroCluster
- Install a MetroCluster IP configuration
- Install a stretch MetroCluster configuration
- Transition from MetroCluster FC to MetroCluster IP
Creating your file...
Your file is ready
After completing the transition of the MetroCluster configuration, you can resume monitoring with the Tiebreaker or Mediator utility.
Use the appropriate procedure for your configuration.
If you are using…
Use this procedure
Tiebreaker
Mediator
link:../install-ip/concept_mediator_requirements.html #configuring-the-ontap-mediator-service-from-a-metrocluster-ip-configuration[Configuring the ONTAP Mediator service from a MetroCluster IP configuration]
