ONTAP MetroCluster
Removing the existing configuration from the Tiebreaker or other monitoring software
Contributors netapp-aoife netapp-ranuk
If the existing configuration is monitored with the MetroCluster Tiebreaker configuration or other third-party applications (for example, ClusterLion) that can initiate a switchover, you must remove the MetroCluster configuration from the Tiebreaker or other software prior to transition.
  1. Remove the existing MetroCluster configuration from the Tiebreaker software.
  2. Remove the existing MetroCluster configuration from any third-party application that can initiate switchover.
    Refer to the documentation for the application.
