Installing and cabling MetroCluster components for two-node SAS-attached stretch configurations
PDF of this doc site
- Install a fabric-attached MetroCluster
- Install a MetroCluster IP configuration
- Install a stretch MetroCluster configuration
- Transition from MetroCluster FC to MetroCluster IP
Creating your file...
The storage controllers must be cabled to the storage media and to each other. The storage controllers must also be cabled to the data and management network.
Before you begin any procedure in this document
The following overall requirements must be met before completing this task:
Prior to installation you must have familiarized yourself with the considerations and best practices for installing and cabling disk shelves for your disk shelf model.
All MetroCluster components must be supported.
In the IMT, you can use the Storage Solution field to select your MetroCluster solution. Use the Component Explorer to select the components and ONTAP version to refine your search. You can click Show Results to display the list of supported configurations that match the criteria.
About this task
The terms node and controller are used interchangeably.
