Learn about Digital Advisor reports
Digital Advisor provides a variety of reporting options that enable you to monitor and manage your system health and operation success.
The following are the types of reports that are available in Digital Advisor:
| Report Name | Description | Available in ONTAP | Available in E-Series | Available in StorageGRID |
Ansible Inventory |
Provides an Ansible inventory file which lists all system inventory details by region or site. This file can be used for automation. |
Yes |
No |
No |
Capacity & Efficiency |
Provides information about the Capacity and Efficiency details at cluster, customer, site, group, watchlist and node level. |
Yes |
Yes |
Yes |
Cloud Recommendations |
Provides insights and recommendations for optimizing cloud resources. It includes details on disaster recovery, backup, tiering, and migration. |
Yes |
No |
No |
ClusterViewer |
Provides information about a single or multiple clusters at a customer and watchlist level. You can generate this report only for watchlist with up to 100 nodes. |
Yes |
No |
No |
Config Drift |
Allows users to establish a "golden baseline" for system configurations and alerts them when deviations from this baseline occur. It helps identify and address configuration changes that may impact system performance or security. |
Yes |
No |
No |
Delivery Logistics |
Provides information about the logistics of delivering products and services. |
Yes |
Yes |
No |
Health Assessment Executive Summary |
Provides information about various Digital Advisor KPIs in a PowerPoint (PPT) format, with different KPI being described on different slides. |
Yes |
Yes |
No |
Inventory |
Provides information about the install base for a selected watchlist, customer, site, group levels. This report can be generated either as a direct download from Inventory details page or can be generated from Reports page. |
Yes |
Yes |
Yes |
IO Density |
IO Density Report provides insights into peak input-output operations for customers in terms of data and meta-data consumption and density. |
Yes |
No |
No |
Performance |
Provides information, at a watchlist level, about the performance of a cluster, node, local tier (aggregate), and volume. You can generate this report only for watchlist with up to 100 nodes. |
Yes |
Yes |
No |
Periodic Digest |
Summarizes key metrics and insights periodically. It includes data on system performance, capacity, and efficiency. |
Yes |
No |
No |
Recommended Configuration |
Provides information about the various recommended configuration gaps for Remote Management Configuration, spares and drives, HA Pair, SVM Health, battery status, and recovery guru advisories. |
Yes |
Yes |
No |
Security |
Provides a comprehensive, exportable overview of ONTAP storage security risks and compliance gaps across clusters, SVMs, and volumes. |
Yes |
No |
No |
Support Contracts / Hardware EOS |
Provides information about the contract details and the list of controllers, shelves, and disks, that have reached end-of-support (EOS). |
Yes |
Yes |
No |
Technical Case Details |
Provides a yearly report about all the technical cases and their status. |
Yes |
Yes |
Yes |
Upgrade Plan |
Offers recommendations for software and firmware upgrades. It includes details on the latest recommended versions, potential issues, and steps for performing upgrades. |
Yes |
No |
No |
Upgrade Recommendations (SW & FW) |
Multi-tabbed report about the software and firmware currency and recommended versions for each controller or serial in the search criteria. |
Yes |
Yes |
No |
Volume Performance |
Provides information about the performance details of the volumes at the cluster level. |
Yes |
No |
No |
Wellness |
Provides information about the outstanding and acknowledged risks, risk details, corrective actions, and affected systems. |
Yes |
Yes |
Yes |
