Protect storage systems managed by Digital Advisor from ransomware risks
When you log in to the Digital Advisor, you can view the Actions highlighted on the Security & Ransomware Defense widget, which shows the risk counts.
You can view the snapshot creation, retention, and ONTAP FPolicy risks, and then take actions to fix them.
Steps
Log in to Digital Advisor.
Select Actions on the Security & Ransomware Defense widget.
Clear the Security Vulnerabilities checkbox.
For the risks that are displayed, check the impact level and follow the recommended actions.
Select the Unique Risks tab and select the link in the Corrective Action column.
Select the Affected Systems tab to view systems with risks.
Select the remediation actions that are recommended to protect the systems.
