Digital Advisor
Download the AFF and FAS firmware Ansible package from Digital Advisor
Contributors manishc netapp-barbe netapp-revathid netapp-reenu
You should update the AFF and FAS firmware using Ansible to mitigate the identified risks and keep your storage system up to date.
Before you begin
Before updating AFF and FAS firmware using Ansible, you should:
Steps
  1. Select any wellness widget on the dashboard or select View All Actions to view a list of all the actions and risks.
  2. Select Firmware Upgrade to view all firmware upgrade risks.
  3. Select Update AFF and FAS Firmware to view all available update packages or select Update Ansible next to each risk to update the package specific to that risk.
  4. Select Download to download the zip files and update your storage system.
    The zip file contains the following:
    • Ansible Playbook - A YAML file containing the Ansible script to perform the disk, shelf, and service processor firmware updates.
    • Inventory - A YAML file containing the details of the systems that are applicable for firmware updates.
    • Disk, Shelf, and Service Processor/BMC Firmware packages are named as all.zip, all_shelf_fw.zip, and <SP/BMC>_<version_number>_fw.zip respectively.
Note Manual addition of clusters and controllers to the inventory file is not supported.
