Validate the AFF and FAS firmware installation on your storage system
After the execution of the playbook, log in to the cluster as the cluster administrator.
Validate disk firmware installation
Verify that the drive firmware is installed:
::*> storage disk show -fields firmware-revision,model disk firmware-revision model --------------- ----------------- ---------------- 1.11.0 NA01 X423_HCOBE900A10 1.11.1 NA01 X423_HCOBE900A10 1.11.2 NA01 X423_HCOBE900A10 1.11.3 NA01 X423_HCOBE900A10 1.11.4 NA01 X423_HCOBE900A10
For more information about the command, refer to storage disk show.
Verify that the new NVMe Flash Cache firmware is installed:
::*> system controller flash-cache show
For more information about the command, refer to system controller flash-cache show.
Validate shelf firmware installation
Verify that the new shelf firmware is updated:
::*> system node run -node * -command sysconfig -v
In the output, verify that each shelf's firmware is updated to the desired level. For example:
Shelf 1: IOM6 Firmware rev. IOM6 A: 0191 IOM3 B: 0191
For more information about the command, refer to system node run.
Verify that the new ACP firmware is updated:
::*> storage shelf acp module show -instance
For more information about the command, refer to storage shelf acp module show.
Verify that the desired ACP mode is configured:
::*> storage shelf acp show
For more information about the command, refer to storage shelf acp show.
Change the ACP mode (channel):
::*> storage shelf acp configure -channel [in-band | out-of-band]
For more information about the command, refer to storage shelf acp configure.
Validating SP/BMC Firmware installation
The Ansible Playbook for Service Processor/BMC firmware updates is enabled with an option to verify the installation of latest SP/BMC firmware on the controller. After the verification is complete (the updates could take a maximum time of two hours), the Ansible Playbook applies internal switch firmware updates by connecting to the SP/BMC console.
The failure and success information for SP/BMC firmware and the internal switch firmware installations will be notified at the end of Ansible Playbook execution. Follow the steps mentioned in the Ansible Playbook in case the SP/BMC firmware/internal switch firmware installation fails.
