Digital Advisor
View storage system risks in Digital Advisor and take corrective actions
Contributors manishc netapp-barbe netapp-revathid FarheenViquas
You can analyze the wellness attributes of your storage system by viewing the actions and risks associated with them. You should view the associated corrective actions and manually mitigate the risk.
Steps
  1. Select the Wellness widget on the dashboard or select View All Actions to view the list of all the actions and risks.
  2. View the Actions and Risks associated with the wellness attribute.
  3. Select Actions to view the risks associated with the actions, select Risks to view all the risks, or select Affected Systems to view the systems that require attention.
  4. Select the risk name to view information about the risk.
  5. Select the associated corrective actions and follow the information to resolve the risk.
The steps to mitigate the risks are same for all wellness attributes. You can view the following video to monitor and fix security related issues:
