Digital Advisor
View your storage system inventory details in Digital Advisor
Contributors manishc netapp-manishc netapp-barbe FarheenViquas
The Inventory widget provides you with a rollup of the total systems and the support entitled switches that you own. This includes both Digital Advisor enabled and non-enabled products.
You can also generate the report of the selected watchlist and email the report to a maximum of 5 recipients.
View system details
Steps
  1. In the Inventory widget, select Systems to view the system information of all platforms or select the platform type and then select Systems to view systems specific to that platform.
  2. Select the node or cluster to view detailed information about the system.
  3. Select Download to download the Inventory report to view the system details in .xls format.
  4. Select Download to download the Ansible Inventory report to view the system details in the .yml and .ini formats at the region or site level.
    The Ansible Inventory files can be used with customized Ansible Playbook files to make infrastructure configuration changes.
View support entitled switch details
Steps
  1. In the Inventory widget, select Support Entitled Switches to view information about all the support entitled switches.
