Access the Sustainability dashboard in Digital Advisor
Sustainability dashboard provides AIOps-enabled reporting and scoring with actionable insights to improve your sustainability posture. You can access the sustainability dashboard through NetApp Console or Digital Advisor.
To log in to the Console, you can use your NetApp Support Site credentials or you can sign up for a NetApp Console login using your email and a password. Learn more about logging in to the Console.
Open a web browser, and go to the Console.
The Console login page appears. -
Log in to Console.
From the Console left navigation, select Health > Sustainability.
The Sustainability dashboard appears.
If the Sustainability dashboard is not set up, the option Add NSS account appears. Provide your NetApp Support Site (NSS) credentials to view your Sustainability dashboard and the systems associated with your account. |
To log in to Digital Advisor, you can use your NetApp Support Site credentials.
Open a web browser, and go to the Digital Advisor login page.
Provide your username and password and select Sign In.
From the left navigation, select Sustainability.
The Sustainability option is disabled if the watchlist is not configured. To enable it, you can either create a watchlist or perform a search using customer name, site name, group name, StorageGRID, hostname, cluster, serial number, or system ID. Learn more about watchlist. |
