Analyze wellness attributes in Digital Advisor and acknowledge risks
You can analyze the wellness attributes of your storage system by viewing the actions and risks associated with them. You should view the corrective actions and manually mitigate the risk.
Select the wellness attribute widget on the dashboard or select View All Actions to view the list of all the actions and risks.
View the Actions and Risks associated with the wellness attribute.
Select Actions to view the risks associated with the actions, select Risks to view all the risks, or select Affected Systems to view the systems that require attention.
Select the risk to view the risk summary.
Select Ack to acknowledge the risk.
The detailed risk summary information is provided along with corrective actions that should be manually performed to mitigate the risk.
If you do not want to or are unable to mitigate the risk at this time, provide the values for the fields and select Acknowledge.
The risk will be added to acknowledged risks.
If you no longer want a risk to be acknowledged, you can disregard the risk by selecting Un-Ack and following the same steps. |
