Digital Advisor
Use Digital Advisor to fix critical risks identified in the Availability and Protection widget
Contributors netapp-manishc netapp-revathid FarheenViquas netapp-barbe
When you log in to the Digital Advisor and notice the red badge on the Availability and Protection widget, you can take actions to fix critical risks. Without the firmware fix, these drives are vulnerable to become inoperable after a certain number of hours of being powered on. Fixing this would avoid both the downtime and possible data loss.
Steps
  1. Log in to the Digital Advisor.
  2. Select Actions in the Availability & Protection widget.
    For the high-impact security risks, follow the recommended action that is to update disk firmware.
  3. Select the Risk Name link for viewing risk summary.
    Risk summary
  4. Select the Unique Risks tab, and then select the link in the Corrective Action column.
    Corrective action
    Digital Advisor generates custom Ansible scripts or playbooks to update the required disk firmware, including the disk firmware files.
  5. Select the Ansible “A” icon to generate and download the scripts.
    AFF and FAS firmware
