Digital Advisor
Known limitations in Digital Advisor
Contributors manishc netapp-manishc netapp-barbe netapp-soumikd
Known limitations identify platforms, devices, or functions that are not supported by this release of the product, or that do not interoperate correctly with it. Review these limitations carefully.
Editing a watchlist may take 60 minutes to reflect in Digital Advisor
Editing a watchlist does not update the information in Digital Advisor immediately. It may take up to 60 minutes for the changes to reflect in Digital Advisor.
A blank report is displayed while scheduling reports
Scheduled reports are available only with a SupportEdge Advisor or a SupportEdge Expert support contract. If your systems are not under SupportEdge Advisor or a SupportEdge Expert support contract, you may get a blank report while scheduling reports.
Acknowledged and unacknowledged risks may take 60 minutes to reflect in Digital Advisor
The status of the risks that are acknowledged and unacknowledged do not reflect immediately in Digital Advisor. It may take up to 60 minutes for the changes to reflect in Digital Advisor and in wellness report.
AutoSupport Widget not available for cluster and serial numbers
The AutoSupport widget will not provide alerts for cluster and serial number searches.
AutoSupport Widget not able to drill down to serial level AutoSupport details
On the AutoSupport Reporting page, selecting on any of the statuses, systems that recently stopped sending, or systems that have AutoSupport turned off does not navigate to the Health Check screen.
Filtering and sorting are not available in the Inventory widget
You cannot filter and sort data in the inventory widget. No data is displayed if you select ONTAP AFF, ONTAP ASA, ONTAP Edge, or ONTAP Select in the "Filter by" drop-down.
