Digital Advisor
Create a watchlist in Digital Advisor
Contributors manishc netapp-shwetav netapp-barbe FarheenViquas
You can create a watchlist to access a set of storage systems quickly and easily. You can add the storage systems based on category or serial number.
Note You can add a maximum of 15,000 storage systems under a category and 500 storage systems under a serial number.
Steps
  1. From the left pane, select Watchlists
    The Manage Watchlist screen is displayed.
  2. Select Create Watchlist.
  3. Provide a name for the watchlist.
  4. Select one of the following options to add storage systems to the watchlist:
    • Category: This option enables you to add the entire inventory associated with a specific category, such as customer, site, group, or Keystone subscriptions, to your watchlist.
      Note The Keystone Subscriptions option allows you to include any subscription numbers associated with Keystone subscriptions. On searching by a watchlist, you can view the subscriptions in the Keystone Subscriptions widget on the Digital Advisor dashboard. For more information, see Search by Keystone watchlists.
    • Serial Number: This option enables you to include inventory in your watchlist based on specified serial numbers. You can either input the serial number directly or select serial numbers from categories like customer, site, or group.
  5. Select Create Watchlist.
    The watchlist dashboard is displayed.
