Improve sustainability score
BlueXP sustainability dashboard generates recommended actions that you can use to improve your overall sustainability posture. You can view these recommended actions from NetApp BlueXP or Digital Advisor.
Go to Sustainability from the Governance category available in the BlueXP left navigation.
Go to the Recommended actions tab.
You can take these actions immediately by selecting Fix, or address later by selecting Later.
If you plan to address the actions immediately, select Fix.
It expands the view of the selected recommended action. You can also expand the recommended action view by using the down arrow. In the expanded view, you can see the cluster name, the sustainability score, and subsequent increase if you proceed with the Fix option. You can also see an informative message of proceeding with the Fix option.
From the expanded view, you can select Fix to address the action immediately.
If you plan to address the actions later, select Later.
If you select Later, it moves the selected recommended action to the Actions for later tab. The selected action will be postponed for 30 days. After 30 days, this action will move to the Recommended actions tab.
You can also review the postponed actions anytime and can move them to the Recommended actions tab by clicking Consider.
Go to Sustainability from the STORAGE HEALTH category available in the left navigation of Digital Advisor dashboard.
The view of the selected recommended action expands. You can also expand the recommended action view by using the down arrow. In the expanded view, you can see the cluster name, the sustainability score, and subsequent increase if you proceed with the Fix option. You can also see an informative message of proceeding with the Fix option.
