Backup Settings dialog box
Define the backup schedule, the retention count, and when using MySQL database dump backup method, the backup path for a selected Unified Manager instance.
You can change the following database backup settings:
Path
When you are using the MySQL database dump backup method, this field specifies the path to the location where you store the backup files. When using the Snapshot backup method, this location shows the cluster, storage VM, and volume on which the backup will be stored.
The following table specifies the backup path format, and default locations, for different operating systems:
Host operating system Backup path format Virtual appliance
/opt/netapp/data/ocum-backupRed Hat Enterprise Linux or CentOS Linux
/data/ocum-backupMicrosoft Windows
C:\ProgramData\NetApp\OnCommandAppData\ocum\backup\ -
Retention Count
Specifies the maximum number of backups to be retained by Unified Manager. The default value is 10.
Scheduled Daily
Specifies the daily backup schedule with the time.
Scheduled Weekly
Specifies the weekly backup schedule with the day and time.
None
Specifies that no backups will be created.
