Keystone
3.0
Keystone STaaS billing for specific volume types
Contributors netapp-shwetav netapp-manini netapp-aruldeepa netapp-bcammett
Keystone STaaS billing rules differ for certain volume configurations. Knowing these exceptions helps you avoid unexpected charges when working with cloned volumes, SnapMirror destinations, LUNs, or temporary storage.
The following table summarizes the billing rules for each volume type.
Volume type Billing rule
Cloned volumes
Billed as standard volumes
Temporary volumes
Not billed
Billed at the destination performance service level
LUNs
Billed at the performance service level of the containing volume
System and root volumes
Monitored but not billed
Billing for cloned volumes
Cloned volumes are billed as standard volumes at the same performance service level as the volume they were cloned from. All cloned volumes are measured and charged regardless of their size or purpose.
Billing for temporary volumes
Occasionally, temporary (TMP) volumes are created by ONTAP when moving volumes. These temporary volumes are short-lived, and the consumption on these volumes is not measured for billing.
Billing for SnapMirror destinations
The pricing for SnapMirror destination volumes, whether used for disaster recovery or long-term retention, is based on the performance service level assigned to the destination. There is no extra fee for data protection.
Billing for LUNs
For LUNs, the billing is based on the performance service levels of the volume.
System and root volumes are monitored as a part of the overall monitoring of the Keystone service but are not counted or billed. The consumption on these volumes is exempted for billing.
