Enterprise applications
ONTAP Mediator
Contributors jfsinmsp
The mediator is required for safely automating failover. Ideally, it would be placed on an independent 3rd site, but it can still function for most needs if colocated with one of the clusters participating in replication.
The mediator is not really a tiebreaker, although that is effectively the function it provides. The mediator helps in determining the state of the cluster nodes and assists in the automatic switchover process in the event of a site failure. Mediator does not transfer data under any circumstances.
SnapMirror active sync diagram with mediator
The #1 challenge with automated failover is the split-brain problem, and that problem arises if your two sites lose connectivity with each other. What should happen? You do not want to have two different sites designate themselves as the surviving copies of the data, but how can a single site tell the difference between actual loss of the opposite site and an inability to communicate with the opposite site?
This is where the mediator enters the picture. If placed on a 3rd site, and each site has a separate network connection to that site, then you have an additional path for each site to validate the health of the other. Look at the picture above again and consider the following scenarios.
  • What happens if the mediator fails or is unreachable from one or both sites?
    • The two clusters can still communicate with each other over the same link used for replication services.
    • Data is still served with RPO=0 protection
  • What happens if Site A fails?
    • Site B will see both of the communication channels go down.
    • Site B will take over data services, but without RPO=0 mirroring
  • What happens if Site B fails?
    • Site A will see both of the communication channels go down.
    • Site A will take over data services, but without RPO=0 mirroring
There is one other scenario to consider: Loss of the data replication link. If the replication link between sites is lost, RPO=0 mirroring will obviously be impossible. What should happen then?
This is controlled by the preferred site status. In an SM-as relationship, one of the sites is secondary to the other. This has no effect on normal operations, and all data access is symmetric, but if replication is interrupted then the tie will have to be broken to resume operations. The result is the preferred site will continue operations without mirroring and the secondary site will halt IO processing until replication communication is restored.
