MetroCluster and NVFAIL
NVFAIL is a general data integrity feature in ONTAP that is designed to maximize data integrity protection with databases.
This section expands on the explanation of basic ONTAP NVFAIL to cover MetroCluster-specific topics. |
With MetroCluster, a write is not acknowledged until it has been logged into local NVRAM and NVRAM on at least one other controller. This approach makes sure that a hardware failure or power outage does not result in the loss of in-flight I/O. If the local NVRAM fails or the connectivity to other nodes fails, then data would no longer be mirrored.
If the local NVRAM reports an error, the node shuts down. This shutdown results in failover to a partner controller when HA pairs are used. With MetroCluster, the behavior depends on the overall configuration chosen, but it can result in automatic failover to the remote note. In any case, no data is lost because the controller experiencing the failure has not acknowledged the write operation.
A site-to-site connectivity failure that blocks NVRAM replication to remote nodes is a more complicated situation. Writes are no longer replicated to the remote nodes, creating a possibility of data loss if a catastrophic error occurs on a controller. More importantly, attempting to fail over to a different node during these conditions results in data loss.
The controlling factor is whether NVRAM is synchronized. If NVRAM is synchronized, node-to-node failover is safe to proceed without the risk of data loss. In a MetroCluster configuration, if NVRAM and the underlying aggregate plexes are in sync, it is safe to proceed with the switchover without the risk of data loss.
ONTAP does not permit a failover or switchover when the data is out of sync unless the failover or switchover is forced. Forcing a change in conditions in this manner acknowledges that data might be left behind in the original controller and that data loss is acceptable.
Databases are especially vulnerable to corruption if a failover or switchover is forced because databases maintain larger internal caches of data on disk. If a forced failover or switchover occurs, previously acknowledged changes are effectively discarded. The contents of the storage array effectively jump backward in time, and the state of the database cache no longer reflects the state of the data on disk.
To protect applications from this situation, ONTAP allows volumes to be configured for special protection against NVRAM failure. When triggered, this protection mechanism results in a volume entering a state called NVFAIL. This state results in I/O errors that cause an application shutdown so that they do not use stale data. Data should not be lost because any acknowledged writes are still present on the storage system, and with databases any committed transaction data should be present in the logs.
The usual next steps are for an administrator to fully shut down the hosts before manually placing the LUNs and volumes back online again. Although these steps can involve some work, this approach is the safest way to make sure of data integrity. Not all data requires this protection, which is why NVFAIL behavior can be configured on a volume-by-volume basis.
Manually forced NVFAIL
The safest option to force a switchover with an application cluster (including VMware, Oracle RAC, and others) that is distributed across sites is by specifying -force-nvfail-all at the command line. This option is available as an emergency measure to make sure that all cached data is flushed. If a host is using storage resources originally located on the disaster-stricken site, it receives either I/O errors or a stale file handle (ESTALE) error. Oracle databases crash and file systems either go offline entirely or switch to read-only mode.
After the switchover is complete, the in-nvfailed-state flag needs to be cleared, and the LUNs need to be placed online. After this activity is complete, the database can be restarted. These tasks can be automated to reduce the RTO.
dr-force-nvfail
As a general safety measure, set the dr-force-nvfail flag on all volumes that might be accessed from a remote site during normal operations, meaning they are activities used prior to failover. The result of this setting is that select remote volumes become unavailable when they enter in-nvfailed-state during a switchover. After the switchover is complete, the in-nvfailed-state flag must be cleared, and the LUNs must be placed online. After these activities are complete, the applications can be restarted. These tasks can be automated to reduce the RTO.
The result is like using the -force-nvfail-all flag for manual switchovers. However, the number of volumes affected can be limited to just those volumes that must be protected from applications or operating systems with stale caches.
There are two critical requirements for an environment that does not use dr-force-nvfail on application volumes:
A forced switchover must occur no more than 30 seconds after primary site loss.
A switchover must not occur during maintenance tasks or any other conditions in which SyncMirror plexes or NVRAM replication are out of sync. The first requirement can be met by using tiebreaker software that is configured to perform a switchover within 30 seconds of a site failure. This requirement does not mean the switchover must be performed within 30 seconds of the detection of a site failure. It does mean that it is no longer safe to force a switchover if 30 seconds have elapsed since a site was confirmed to be operational.
The second requirement can be partially met by disabling all automated switchover capabilities when the MetroCluster configuration is known to be out of sync. A better option is to have a tiebreaker solution that can monitor the health of NVRAM replication and the SyncMirror plexes. If the cluster is not fully synchronized, the tiebreaker should not trigger a switchover.
The NetApp MCTB software cannot monitor the synchronization status, so it should be disabled when MetroCluster is not in sync for any reason. ClusterLion does include NVRAM-monitoring and plex-monitoring capabilities and can be configured to not trigger the switchover unless the MetroCluster system is confirmed to be fully synchronized.
