ONTAP failover/switchover
An understanding of storage takeover and switchover functions is required to ensure that Oracle database operations are not disrupted by these operations. In addition, the arguments used by takeover and switchover operations can affect data integrity if used incorrectly.
Under normal conditions, incoming writes to a given controller are synchronously mirrored to its partner. In a NetApp MetroCluster environment, writes are also mirrored to a remote controller. Until a write is stored in nonvolatile media in all locations, it is not acknowledged to the host application.
The media storing the write data is called nonvolatile memory or NVMEM. It is also sometimes referred to nonvolatile random- access memory (NVRAM), and it can be thought of as a write cache although it functions as a journal. In a normal operation, the data from NVMEM is not read; it is only used to protect data in the event of a software or hardware failure. When data is written to drives, the data is transferred from the RAM in the system, not from NVMEM.
During a takeover operation, one node in a high availability (HA) pair takes over the operations from its partner. A switchover is essentially the same, but it applies to MetroCluster configurations in which a remote node takes over the functions of a local node.
During routine maintenance operations, a storage takeover or MetroCluster switchover operation should be transparent, other than for a potential brief pause in operations as the network paths change. Networking can be complicated, however, and it is easy to make errors, so NetApp strongly recommends testing takeover and switchover operations thoroughly before putting a storage system into production. Doing so is the only way to be sure that all network paths are configured correctly. In a SAN environment, carefully check the output of the command sanlun lun show -p to make sure that all expected primary and secondary paths are available.
Care must be taken when issuing a forced takeover or switchover. Forcing a change to storage configuration with these options means that the state of the controller that owns the drives is disregarded and the alternative node forcibly takes control of the drives. Incorrect forcing of a takeover can result in data loss or corruption. This is because a forced takeover or switchover can discard the contents of NVMEM. After the takeover or switchover is complete, the loss of that data means that the data stored on the drives might revert to a slightly older state from the point of view of the database.
A forced takeover with a normal HA pair should rarely be required. In almost all failure scenarios, a node shut downs and informs the partner so that an automatic failover takes place. There are some edge cases, such as a rolling failure in which the interconnect between nodes is lost and then one controller is lost, in which a forced takeover is required. In such a situation, the mirroring between nodes is lost before the controller failure, which means that the surviving controller would have no longer has a copy of the writes in progress. The takeover then needs to be forced, which means that data potentially is lost.
The same logic applies to a MetroCluster switchover. In normal conditions, a switchover is nearly transparent. However, a disaster can result in a loss of connectivity between the surviving site and the disaster site. From the point of view of the surviving site, the problem could be nothing more than an interruption in connectivity between sites, and the original site might still be processing data. If a node cannot verify the state of the primary controller, only a forced switchover is possible.
NetApp recommends taking the following precautions:
MetroCluster and multiple aggregates
MetroCluster is a synchronous replication technology that switches to asynchronous mode if connectivity is interrupted. This is the most common request from customers, because guaranteed synchronous replication means that interruption in site connectivity leads to a complete stall of database I/O, taking the database out of service.
With MetroCluster, aggregates rapidly resynchronize after connectivity is restored. Unlike other storage technologies, MetroCluster should never require a complete remirroring after site failure. Only delta changes must be shipped.
In datasets that span aggregates, there is a small risk that additional data recovery steps would be required in a rolling disaster scenario. Specifically, if (a) connectivity between sites is interrupted, (b) connectivity is restored, (c) the aggregates reach a state in which some are synchronized and some are not, and then (d) the primary site is lost, the result is a surviving site in which the aggregates are not synchronized with one another. If this happens, parts of the dataset are synchronized with one another and it is not possible to bring up applications, databases, or datastores without recovery. If a dataset spans aggregates, NetApp strongly recommends leveraging snapshot-based backups with one of the many available tools to verify rapid recoverability in this unusual scenario.
