LUN placement
Optimal placement of database LUNs within ONTAP volumes on AFF and FAS systems primarily depends on how various ONTAP features will be used.
This section applies to AFF and FAS systems.
ASA is a streamlined SAN platform and does not expose a volume abstraction layer,
Volumes
One common point of confusion with customers new to ONTAP is the use of FlexVols, commonly referred to as simply "volumes".
A volume is not a LUN. These terms are used synonymously with many other vendor products, including cloud providers. ONTAP volumes are simply management containers. They do not serve data by themselves, nor do they occupy space. They are containers for files or LUNs and exist to improve and simplify manageability, especially at scale.
Volumes and LUNs
Related LUNs are normally co-located in a single volume. For example, a database that requires 10 LUNs would typically have all 10 LUNs placed on the same volume.
Volumes, LUNs, and snapshots
Snapshot policies and schedules are placed on the volume, not the LUN. A dataset that consists of 10 LUNs would require only a single snapshot policy when those LUNs are co-located in the same volume.
Additionally, co-locating all related LUNs for a given dataset in a single volume delivers atomic snapshot operations. For example, a database that resided on 10 LUNs, or a VMware-based application environment consisting of 10 different OSs could be protected as a single, consistent object if the underlying LUNs are all placed on a single volume. If they are placed on different volumes, the snapshots may or may not be 100% in sync, even if scheduled at the same time.
In some cases, a related set of LUNs might need to be split into two different volumes because of recovery requirements. For example, a database might have four LUNs for datafiles and two LUNs for logs. In this case, a datafile volume with 4 LUNs and a log volume with 2 LUNs might be the best option. The reason is independent recoverability. For example, the datafile volume could be selectively restored to an earlier state, meaning all four LUNs would be reverted to the state of the snapshot, while the log volume with its critical data would be unaffected.
Volumes, LUNs, and SnapMirror
SnapMirror policies and operations are, like snapshot operations, performed on the volume, not the LUN.
Co-locating related LUNs in a single volume allows you to create a single SnapMirror relationship and update all contained data with a single update. As with snapshots, the update will also be an atomic operation. The SnapMirror destination would be guaranteed to have a single point-in-time replica of the source LUNs. If the LUNs were spread across multiple volumes, the replicas may or may not be consistent with one another.
Volumes, LUNs, and QoS
While QoS can be selectively applied to individual LUNs, it is usually easier to set it at the volume level. For example, all of the LUNs used by the guests in a given ESX server could be placed on a single volume, and then an ONTAP adaptive QoS policy could be applied. The result is a self-scaling IOPS-per-TB limit that applies to all LUNs.
Likewise, if a database required 100K IOPS and occupied 10 LUNs, it would be easier to set a single 100K IOPS limit on a single volume than to set 10 individual 10K IOPS limits, one on each LUN.
Multi-volume layouts
There are some cases where distributing LUNs across multiple volumes may be beneficial. The primary reason is controller striping. For example, an HA storage system might be hosting a single database where the full processing and caching potential of each controller is required. In this case, a typical design would be to place half of the LUNs in a single volume on controller 1, and the other half of the LUNs in a single volume on controller 2.
Similarly, controller striping might be used for load balancing. An HA system that hosted 100 databases of 10 LUNs each might be designed where each database receives a 5-LUN volume on each of the two controllers. The result is guaranteed symmetric loading of each controller as additional databases are provisioned.
None of these examples involve a 1:1 volume to LUN ratio, though. The goal remains to optimize manageability by co-locating related LUNs in volumes.
One example where a 1:1 LUN to volume ratio makes sense is containerization, where each LUN might really represent a single workload and need to be each managed on an individual basis. In such cases, a 1:1 ratio may be optimal.
