NFS leases and locks
NFSv3 is stateless. That effectively means that the NFS server (ONTAP) doesn't keep track of which file systems are mounted, by whom, or which locks are truly in place.
ONTAP does have some features that will record mount attempts so you have an idea which clients may be accessing data, and there may be advisory locks present, but that information isn't guaranteed to be 100% complete. It can't be complete, because tracking NFS client state is not part of the NFSv3 standard.
NFSv4 statefulness
In contrast, NFSv4 is stateful. The NFSv4 server tracks which clients are using which file systems, which files exist, which files and/or regions of files are locked, etc. This means there needs to be regular communication between an NFSv4 server to keep the state data current.
The most important states being managed by the NFS server are NFSv4 Locks and NFSv4 Leases, and they are very much intertwined. You need to understand how each works by itself, and how they relate to one another.
NFSv4 locks
With NFSv3, locks are advisory. An NFS client can still modify or delete a "locked" file. An NFSv3 lock doesn't expire by itself, it must be removed. This creates problems. For example, if you have a clustered application that creates NFSv3 locks, and one of the nodes fails, what do you do? You can code the application on the surviving nodes to remove the locks, but how do you know that's safe? Maybe the "failed" node is operational, but isn't communicating with the rest of the cluster?
With NFSv4, locks have a limited duration. As long as the client holding the locks continues to check in with the NFSv4 server, no other client is permitted to acquire those locks. If a client fails to check in with the NFSv4, the locks eventually get revoked by the server and other clients will be able to request and obtain locks.
NFsv4 leases
NFSv4 locks are associated with an NFSv4 lease. When an NFSv4 client establishes a connection with an NFSv4 server, it gets a lease. If the client obtains a lock (there are many types of locks) then the lock is associated with the lease.
This lease has a defined timeout. By default, ONTAP will set the timeout value to 30 seconds:
Cluster01::*> nfs server show -vserver vserver1 -fields v4-lease-seconds vserver v4-lease-seconds --------- ---------------- vserver1 30
This means that an NFSv4 client needs to check in with the NFSv4 server every 30 seconds to renew its leases.
The lease is automatically renewed by any activity, so if the client is doing work there's no need to perform addition operations. If an application becomes quiet and is not doing real work, it's going to need to perform a sort of keep-alive operation (called a SEQUENCE) instead. It's essentially just saying "I'm still here, please refresh my leases."
*Question:* What happens if you lose network connectivity for 31 seconds?
NFSv3 is stateless. It's not expecting communication from the clients. NFSv4 is stateful, and once that lease period elapses, the lease expires, and locks are revoked and the locked files are made available to other clients.
With NFSv3, you could move network cables around, reboot network switches, make configuration changes, and be fairly sure that nothing bad would happen. Applications would normally just wait patiently for the network connection to work again.
With NFSv4, you have 30 seconds (unless you've increased the value of that parameter within ONTAP) to complete your work. If you exceed that, your leases time out. Normally this results in application crashes.
As an example, if you have an Oracle database, and you experience a loss of network connectivity (sometimes called a "network partition") that exceeds the lease timeout, you will crash the database.
Here's an example of what happens in the Oracle alert log if this happens:
2022-10-11T15:52:55.206231-04:00 Errors in file /orabin/diag/rdbms/ntap/NTAP/trace/NTAP_ckpt_25444.trc: ORA-00202: control file: '/redo0/NTAP/ctrl/control01.ctl' ORA-27072: File I/O error Linux-x86_64 Error: 5: Input/output error Additional information: 4 Additional information: 1 Additional information: 4294967295 2022-10-11T15:52:59.842508-04:00 Errors in file /orabin/diag/rdbms/ntap/NTAP/trace/NTAP_ckpt_25444.trc: ORA-00206: error in writing (block 3, # blocks 1) of control file ORA-00202: control file: '/redo1/NTAP/ctrl/control02.ctl' ORA-27061: waiting for async I/Os failed
If you look at the syslogs, you should see several of these errors:
Oct 11 15:52:55 host1 kernel: NFS: nfs4_reclaim_open_state: Lock reclaim failed! Oct 11 15:52:55 host1 kernel: NFS: nfs4_reclaim_open_state: Lock reclaim failed! Oct 11 15:52:55 host1 kernel: NFS: nfs4_reclaim_open_state: Lock reclaim failed!
The log messages are usually the first sign of a problem, other than the application freeze. Typically, you see nothing at all during the network outage because processes and the OS itself are blocked attempting to access the NFS file system.
The errors appear after the network is operational again. In the example above, once connectivity was reestablished, the OS attempted to reacquire the locks, but it was too late. The lease had expired and the locks were removed. That results in an error that propagates up to the Oracle layer and causes the message in the alert log. You might see variations on these patterns depending on the version and configuration of the database.
In summary, NFSv3 tolerates network interruption, but NFSv4 is more sensitive and imposes a defined lease period.
What if a 30 second timeout isn't acceptable? What if you manage a dynamically changing network where switches are rebooted or cables are relocated and the result is the occasional network interruption? You could choose to extend the lease period, but whether you want to do that requires an explanation of NFSv4 grace periods.
NFSv4 grace periods
If an NFSv3 server is rebooted, it's ready to serve IO almost instantly. It was not maintaining any sort of state about clients. The result is that an ONTAP takeover operation often appears to be close to instantaneous. The moment a controller is ready to start serving data it will send an ARP to the network that signals the change in topology. Clients normally detect this almost instantly and data resumes flowing.
NFSv4, however, will produce a brief pause. It's just part of how NFSv4 works.
The following sections are current as of ONTAP 9.15.1, but the lease and lock behavior as well as tuning options can change from version to version. If you need to tune NFSv4 lease/lock timeouts, please consult NetApp support for the latest information. |
NFSv4 servers need to track the leases, locks, and who's using what data. If an NFS server panics and reboots, or loses power for a moment, or is restarted during maintenance activity, the result is the lease/lock and other client information is lost. The server needs to figure out which client is using what data before resuming operations. This is where the grace period comes in.
If you suddenly power cycle your NFSv4 server. When it comes back up, clients that attempt to resume IO will get a response that essentially says, "I have lost lease/lock information. Would you like to re-register your locks?" That's the start of the grace period. It defaults to 45 seconds on ONTAP:
Cluster01::> nfs server show -vserver vserver1 -fields v4-grace-seconds vserver v4-grace-seconds --------- ---------------- vserver1 45
The result is that, after a restart, a controller will pause IO while all the clients reclaim their leases and locks. Once the grace period ends, the server will resume IO operations.
This grace period controls lease reclamation during network interface changes, but there is a second grace period that controls reclamation during storage failover, locking.grace_lease_seconds. This is a node-level option.
cluster01::> node run [node names or *] options locking.grace_lease_seconds
For example, if you frequently needed to perform LIF failovers, and needed to reduce the grace period, you would change v4-grace-seconds. If you wanted to improve the IO resumption time during controller failover, you would need to change locking.grace_lease_seconds.
Only alter these values with caution and after fully understanding the risks and consequences. The IO pauses involved with failover and migration operations with NFSv4.X cannot be avoided entirely. Lock, lease, and grace periods are part of the NFS RFC. For many customers, NFSv3 is preferable because failover times are faster.
Lease timeouts vs grace periods
The grace period and the lease period are connected. As mentioned above, the default lease timeout is 30 seconds, which means NFSv4 clients must check in with the server at least every 30 seconds or they lose their leases and, in turn, their locks. The grace period exists to allow an NFS server to rebuild lease/lock data, and it defaults to 45 seconds. The grace period must be longer than the lease period. This ensures that an NFS client environment that is designed to renew leases at least every 30 seconds will have the ability to check in with the server after a restart. A grace period of 45 seconds ensures that all those clients that expect to renew their leases at least every 30 seconds definitely have the opportunity to do so.
If a 30 second timeout isn't acceptable, you could choose to extend the lease period.
If you want to increase the lease timeout to 60 seconds in order to withstand a 60 second network outage, you're going to have to increase the grace period as well. That means you're going to experience longer IO pauses during controller failover.
This shouldn't normally be a problem. Typical users only update ONTAP controllers once or twice per year, and unplanned failover due to hardware failures are extremely rare. In addition, if you had a network where a 60-second network outage was a concerning possibility, and you needed to the lease timeout to 60 seconds, then you probably wouldn't object to rare storage system failover resulting in a 61 second pause either. You've already acknowledged you have a network that's pausing for 60+ seconds rather frequently.
