Tiering policies
Four policies are available in ONTAP which control how Oracle data on the performance tier become a candidate to be relocated to the capacity tier.
Snapshot-only
The snapshot-only tiering-policy applies only to blocks that are not shared with the active file system. It essentially results in tiering of database backups. Blocks become candidates for tiering after a snapshot is created and the block is then overwritten, resulting in a block that exists only within the snapshot. The delay before a snapshot-only block is considered cool is controlled by the tiering-minimum-cooling-days setting for the volume. The range as of ONTAP 9.8 is from 2 to 183 days.
Many datasets have low change rates, resulting in minimal savings from this policy. For example, a typical database observed on ONTAP has a change rate of less than 5% per week. Database archive logs can occupy extensive space, but they usually continue to exist in the active file system and thus would not be candidates for tiering under this policy.
Auto
The auto tiering policy extends tiering to both snapshot-specific blocks as well as blocks within the active file system. The delay before a block is considered cool is controlled by the tiering-minimum-cooling-days setting for the volume. The range as of ONTAP 9.8 is from 2 to 183 days.
This approach enables tiering options that are not available with the snapshot-only policy. For example, a data protection policy might require 90 days of certain log files to be retained. Setting a cooling period of 3 days results in any log files older than 3 days to be tiered out from the performance layer. This action frees up substantial space on the performance tier while still allowing you to view and manage the full 90 days of data..
None
The none tiering policy prevents any additional blocks from being tiered from the storage layer, but any data still in the capacity tier remains in the capacity tier until it is read. If the block is then read, it is pulled back and placed on the performance tier.
The primary reason to use the none tiering policy is to prevent blocks from being tiered, but it could become useful to change the policies over time. For example, let's say that a specific dataset is extensively tiered to the capacity layer, but an unexpected need for full performance capabilities arises. The policy can be changed to prevent any additional tiering and to confirm that any blocks read back as IO increases remain in the performance tier.
All
The all tiering policy replaces the backup policy as of ONTAP 9.6. The backup policy applied only to data protection volumes, meaning a SnapMirror or NetApp SnapVault destination. The all policy functions the same, but is not restricted to data protection volumes.
With this policy, blocks are immediately considered cool and eligible to be tiered to the capacity layer immediately.
This policy is especially appropriate for long-term backups. It can also be used as a form of Hierarchical Storage Management (HSM). In the past, HSM was commonly used to tier the data blocks of a file to tape while keeping the file itself visible on the file system. A FabricPool volume with the all policy allows you to store files in a visible and manageable yet consuming nearly no space on the local storage tier.
