Enterprise applications
Thin provisioning
Contributors jfsinmsp netapp-chrisgeb
Thin provisioning for an Oracle database requires careful planning because the result is configuring more space on a storage system than is necessarily physically available. It is very much worth the effort because, when done correctly, the result is significant cost savings and improvements in manageability.
Thin provisioning comes in many forms and is integral to many features that ONTAP offers to an enterprise application environment. Thin provisioning is also closely related to efficiency technologies for the same reason: efficiency features allow more logical data to be stored than what technically exists on the storage system.
Almost any use of snapshots involves thin provisioning. For example, a typical 10TB database on NetApp storage includes around 30 days of snapshots. This arrangement results in approximately 10TB of data visible in the active file system and 300TB dedicated to snapshots. The total 310TB of storage usually resides on approximately 12TB to 15TB of space. The active database consumes 10TB, and the remaining 300TB of data only requires 2TB to 5TB of space because only the changes to the original data are stored.
Cloning is also an example of thin provisioning. A major NetApp customer created 40 clones of an 80TB database for use by development. If all 40 developers using these clones overwrote every block in every datafile, over 3.2PB of storage would be required. In practice, turnover is low, and the collective space requirement is closer to 40TB because only changes are stored on the drives.
Space management
Some care must be taken with thin provisioning an application environment because data change rates can increase unexpectedly. For example, space consumption due to snapshots can grow rapidly if database tables are reindexed, or wide-scale patching is applied to VMware guests. A misplaced backup can write a large amount of data in a very short time. Finally, it can be difficult to recover some applications if a file system runs out of free space unexpectedly.
Fortunately, these risks can be addressed with careful configuration of volume-autogrow and snapshot-autodelete policies. As their names imply, these options enable a user to create policies that automatically clear space consumed by snapshots or grow a volume to accommodate additional data. Many options are available and needs vary by customer.
See the logical storage management documentation for a complete discussion of these features.
Fractional reservations
Fractional reserve refers to the behavior of a LUN in a volume with respect to space efficiency. When the option fractional-reserve is set to 100%, all data in the volume can experience 100% turnover with any data pattern without exhausting space on the volume.
For example, consider a database on a single 250GB LUN in a 1TB volume on an AFF system. Creating a snapshot would immediately result in the reservation of an additional 250GB of space in the volume to guarantee that the volume does not run out of space for any reason. Using fractional reserves is generally wasteful because it is extremely unlikely that every byte in the database volume would need to be overwritten. There is no reason to reserve space for an event that never happens. Still, if a customer cannot monitor space consumption in a storage system and must be certain that space never runs out, 100% fractional reservations would be required to use snapshots.
Tip The volume abstraction is not present on SAN-only the ASA, and thus this platform does not use fractional reserves.
Compression and deduplication
Compression and deduplication are both forms of thin provisioning. For example, a 50TB data footprint might compress to 30TB, resulting in a savings of 20TB. For compression to yield any benefits, some of that 20TB must be used for other data, or the storage system must be purchased with less than 50TB. The result is storing more data than is technically available on the storage system. From the data point of view, there is 50TB of data, even though it occupies only 30TB on the drives.
There is always a possibility that the compressibility of a dataset changes, which would result in increased consumption of real space. This increase in consumption means that compression must be managed as with other forms of thin provisioning in terms of monitoring and, on an AFF system, using volume-autogrow and snapshot-autodelete.
Compression and deduplication are discussed in further detail in the section link:efficiency.html
Compression and fractional reservations
Compression is a form of thin provisioning. Fractional reservations affect the use of compression, with one important note; space is reserved in advance of the snapshot creation. Normally, fractional reserve is only important if a snapshot exists. If there is no snapshot, fractional reserve is not important. This is not the case with compression. If a LUN is created on a volume with compression, ONTAP preserves space to accommodate a snapshot. This behavior can be confusing during configuration, but it is expected.
As an example, consider a 10GB volume with a 5GB LUN that has been compressed down to 2.5GB with no snapshots. Consider these two scenarios:
  • Fractional reserve = 100 results in 7.5GB utilization
  • Fractional reserve = 0 results in 2.5GB utilization
The first scenario includes 2.5GB of space consumption for current data and 5GB of space to account for 100% turnover of the source in anticipation of snapshot use. The second scenario reserves no extra space.
Although this situation might seem confusing, it is unlikely to be encountered in practice. Compression implies thin provisioning, and thin provisioning in a LUN environment requires fractional reservations. It is always possible for compressed data to be overwritten by something uncompressible, which means a volume must be thin provisioned for compression to result in any savings.
Tip
NetApp recommends the following reserve configurations with AFF and FAS platforms:
  • Set fractional-reserve to 0 when basic capacity monitoring is in place along with volume-autogrow and snapshot-autodelete.
  • Set fractional-reserve to 100 if there is no monitoring ability or if it is impossible to exhaust space under any circumstance.
Free space and LVM space allocation
The efficiency of thin provisioning of active LUNs in a file system environment can be lost over time as data is deleted. Unless that deleted data is either overwritten with zeros (see also link:oracle-storage-san-config-asm
ru.html[ASMRU] or the space is released with TRIM/UNMAP space reclamation, the "erased" data occupies more and more unallocated whitespace in the file system. Furthermore, thin provisioning of active LUNs is of limited use in many database environments because datafiles are initialized to their full size at the time of creation.
Careful planning of LVM configuration can improve efficiency and minimize the need for storage provisioning and LUN resizing. When an LVM such as Veritas VxVM or Oracle ASM is used, the underlying LUNs are divided into extents that are only used when needed. For example, if a dataset begins at 2TB in size but could grow to 10TB over time, this dataset could be placed on 10TB of thin-provisioned LUNs organized in an LVM diskgroup. It would occupy only 2TB of space at the time of creation and would only claim additional space as extents are allocated to accommodate data growth. This process is safe as long as space is monitored.
