Networking requirements for the Connector
Set up your networking so the Connector can manage resources and processes within your public cloud environment. The most important step is ensuring outbound internet access to various endpoints.
If your network uses a proxy server for all communication to the internet, you can specify the proxy server from the Settings page. Refer to Configuring the Connector to use a proxy server. |
Connection to target networks
A Connector requires a network connection to the type of working environment that you’re creating and the services that you’re planning to enable.
For example, if you install a Connector in your corporate network, then you must set up a VPN connection to the VPC or VNet in which you launch Cloud Volumes ONTAP.
Outbound internet access
The Connector requires outbound internet access to manage resources and processes within your public cloud environment. Outbound internet access is also required if you want to manually install the Connector on a Linux host or access the local UI running on the Connector.
The following sections identify the specific endpoints.
Endpoints to manage resources in AWS
A Connector contacts the following endpoints when managing resources in AWS:
Endpoints | Purpose |
AWS services (amazonaws.com):
The exact endpoint depends on the region in which you deploy Cloud Volumes ONTAP. Refer to AWS documentation for details. |
Enables the Connector to deploy and manage Cloud Volumes ONTAP in AWS. |
https://api.services.cloud.netapp.com:443 |
API requests to NetApp Cloud Central. |
https://cloud.support.netapp.com.s3.us-west-1.amazonaws.com |
Provides access to software images, manifests, and templates. |
https://repo.cloud.support.netapp.com |
Used to download Cloud Manager dependencies. |
http://repo.mysql.com/ |
Used to download MySQL. |
https://cognito-idp.us-east-1.amazonaws.com |
Enables the Connector to access and download manifests, templates, and Cloud Volumes ONTAP upgrade images. |
https://cloudmanagerinfraprod.azurecr.io |
Access to software images of container components for an infrastructure that's running Docker and provides a solution for service integrations with Cloud Manager. |
https://kinesis.us-east-1.amazonaws.com |
Enables NetApp to stream data from audit records. |
https://cloudmanager.cloud.netapp.com |
Communication with the Cloud Manager service, which includes Cloud Central accounts. |
https://netapp-cloud-account.auth0.com |
Communication with NetApp Cloud Central for centralized user authentication. |
https://w86yt021u5.execute-api.us-east-1.amazonaws.com/production/whitelist |
Used to add your AWS account ID to the list of allowed users for Backup to S3. |
https://support.netapp.com/aods/asupmessage |
Communication with NetApp AutoSupport. |
https://support.netapp.com/svcgw |
Communication with NetApp for system licensing and support registration. |
https://client.infra.support.netapp.com.s3.us-west-1.amazonaws.com |
Enables NetApp to collect information needed to troubleshoot support issues. |
https://ipa-signer.cloudmanager.netapp.com |
Enables Cloud Manager to generate licenses (for example, a FlexCache license for Cloud Volumes ONTAP) |
https://packages.cloud.google.com/yum |
Required to connect Cloud Volumes ONTAP systems with a Kubernetes cluster. The endpoints enable installation of NetApp Trident. |
Various third-party locations, for example:
Third-party locations are subject to change. |
During upgrades, Cloud Manager downloads the latest packages for third-party dependencies. |
Endpoints to manage resources in Azure
A Connector contacts the following endpoints when managing resources in Azure:
https://management.azure.com |
Enables Cloud Manager to deploy and manage Cloud Volumes ONTAP in most Azure regions. |
https://management.microsoftazure.de |
Enables Cloud Manager to deploy and manage Cloud Volumes ONTAP in the Azure Germany regions. |
https://management.usgovcloudapi.net |
Enables Cloud Manager to deploy and manage Cloud Volumes ONTAP in the Azure US Gov regions. |
https://mysupport.netapp.com |
*.blob.core.windows.net |
Required for HA pairs when using a proxy. |
Endpoints to manage resources in GCP
A Connector contacts the following endpoints when managing resources in GCP:
https://www.googleapis.com |
Enables the Connector to contact Google APIs for deploying and managing Cloud Volumes ONTAP in GCP. |
Endpoints to install the Connector on a Linux host
You have the option to manually install the Connector software on your own Linux host. If you do, the installer for the Connector must access the following URLs during the installation process:
http://dev.mysql.com/get/mysql-community-release-el7-5.noarch.rpm
https://dl.fedoraproject.org/pub/epel/epel-release-latest-7.noarch.rpm
https://s3.amazonaws.com/aws-cli/awscli-bundle.zip
The host might try to update operating system packages during installation. The host can contact different mirroring sites for these OS packages.
Endpoints accessed from your web browser when using the local UI
While you should perform almost all tasks from the SaaS user interface, a local user interface is still available on the Connector. The machine running the web browser must have connections to the following endpoints:
The Connector host |
You must enter the host's IP address from a web browser to load the Cloud Manager console. Depending on your connectivity to your cloud provider, you can use the private IP or a public IP assigned to the host:
In any case, you should secure network access by ensuring that security group rules allow access from only authorized IPs or subnets. |
https://auth0.com |
Your web browser connects to these endpoints for centralized user authentication through NetApp Cloud Central. |
https://widget.intercom.io |
For in-product chat that enables you to talk to NetApp cloud experts. |
Ports and security groups
There's no incoming traffic to the Connector, unless you initiate it. HTTP and HTTPS provide access to the local UI, which you'll use in rare circumstances. SSH is only needed if you need to connect to the host for troubleshooting.
Rules for the Connector in AWS
The security group for the Connector requires both inbound and outbound rules.
Inbound rules
The source for inbound rules in the predefined security group is 0.0.0.0/0.
Protocol | Port | Purpose |
SSH |
22 |
Provides SSH access to the Connector host |
HTTP |
80 |
Provides HTTP access from client web browsers to the local user interface and connections from Cloud Compliance |
HTTPS |
443 |
Provides HTTPS access from client web browsers to the local user interface |
TCP |
3128 |
Provides the Cloud Compliance instance with internet access, if your AWS network doesn’t use a NAT or proxy |
Outbound rules
The predefined security group for the Connector opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
Basic outbound rules
The predefined security group for the Connector includes the following outbound rules.
All TCP |
All |
All outbound traffic |
All UDP |
All |
Advanced outbound rules
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by the Connector.
The source IP address is the Connector host. |
Service | Protocol | Port | Destination | Purpose |
Active Directory |
TCP |
88 |
Active Directory forest |
Kerberos V authentication |
TCP |
139 |
NetBIOS service session |
TCP |
389 |
LDAP |
TCP |
445 |
Microsoft SMB/CIFS over TCP with NetBIOS framing |
TCP |
464 |
Kerberos V change & set password (SET_CHANGE) |
TCP |
749 |
Active Directory Kerberos V change & set password (RPCSEC_GSS) |
UDP |
137 |
NetBIOS name service |
UDP |
138 |
NetBIOS datagram service |
UDP |
464 |
Kerberos key administration |
API calls and AutoSupport |
HTTPS |
443 |
Outbound internet and ONTAP cluster management LIF |
API calls to AWS and ONTAP, and sending AutoSupport messages to NetApp |
API calls |
TCP |
3000 |
API calls to ONTAP |
TCP |
8088 |
Backup to S3 |
API calls to Backup to S3 |
DNS |
UDP |
53 |
DNS |
Used for DNS resolve by Cloud Manager |
Cloud Compliance |
HTTP |
80 |
Cloud Compliance instance |
Cloud Compliance for Cloud Volumes ONTAP |
Rules for the Connector in Azure
Inbound rules
Port | Protocol | Purpose |
22 |
SSH |
80 |
HTTP |
Provides HTTP access from client web browsers to the local user interface |
443 |
HTTPS |
Outbound rules
All |
All TCP |
All |
All UDP |
Service | Port | Protocol | Destination | Purpose |
Active Directory |
88 |
TCP |
139 |
TCP |
389 |
TCP |
LDAP |
445 |
TCP |
464 |
TCP |
749 |
TCP |
137 |
UDP |
138 |
UDP |
464 |
UDP |
443 |
HTTPS |
API calls |
3000 |
TCP |
DNS |
53 |
UDP |
DNS |
Rules for the Connector in GCP
The firewall rules for the Connector requires both inbound and outbound rules.
Inbound rules
The source for inbound rules in the predefined firewall rules is 0.0.0.0/0.
SSH |
22 |
HTTP |
80 |
HTTPS |
443 |
Outbound rules
The predefined firewall rules for the Connector opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
The predefined firewall rules for the Connector includes the following outbound rules.
All TCP |
All |
All UDP |
All |
Active Directory |
TCP |
88 |
TCP |
139 |
TCP |
389 |
LDAP |
TCP |
445 |
TCP |
464 |
TCP |
749 |
UDP |
137 |
UDP |
138 |
UDP |
464 |
HTTPS |
443 |
API calls to GCP and ONTAP, and sending AutoSupport messages to NetApp |
API calls |
TCP |
3000 |
DNS |
UDP |
53 |
DNS |
