This documentation is for a previous release of Cloud Manager.
Go to the docs for the latest release.
Finding your Cloud Manager system ID
To help you get started, your NetApp representative might ask you for your Cloud Manager system ID. The ID is typically used for licensing and troubleshooting purposes.
What you’ll need
You need to create a Connector before you can change Cloud Manager settings. Learn how.
Steps
In the upper right of the Cloud Manager console, click the Settings icon.
Click Support Dashboard.
Your system ID appears in the top right.
Example
