SnapCenter 5.0 cmdlets
Set-SmCredential
Modify a credential registered with the SnapCenter Server.
Syntax
Set-SmCredential [-Name]  <String>  [-Type]  <SmAuthMode>  [-ClientSecret]  <SecureString>  [-TenantId]  <String>  [-ClientId]  <String>  [-InstanceName]  <String>  [-Force]  <>  [-Credential]  <PSCredential>
Detailed Description
Modify a credential registered with the SnapCenter Server. It could be for other plug-ins or for other NetApp cloud storage.
Name Description Required? Pipeline Input Default Value
Name
Specifies the name of the Credential Account.
true
true (ByPropertyName)
Type
Specifies the authentication mode.
true
ClientSecret
Specifies the Azure NetApp client secret.
false
TenantId
Specifies the Azure NetApp tenant ID.
false
ClientId
Specifies the Azure NetApp client ID.
false
InstanceName
false
Force
false
Credential
true
Example 1: Set Azure Credential
 Set-SmCredential -Name azure -Type AzureCredential -ClientSecret 99634c34-6d2a-9jfb-a47b-0jhg9710037d -TenantId 25434c84-982a-9jfb-a47b-0h6f97076037d -ClientId 87dg98hg-6e2a-498b-m33b-0p2a97134756
Example 2: Modify AIX Credential
 Set-SmCredential -Name 'RunAs1' -CredentialType 'AIX'
Example 3: Modify Authentication Type for Linux Credential
 Set-SmCredential -Name LinuxPasswordBasedRunAs -Type Linux -AuthenticationType SshKeyBased -Username scanf -SSHPrivateKeyPath "C:\Users\Administrator\passwordfile.txt"
