How ONTAP reports disk types in System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
ONTAP System Manager classic (available in ONTAP 9.7 and earlier) associates a type with every disk. ONTAP reports some disk types differently than the industry standards; you should understand how ONTAP disk types map to industry standards to avoid confusion.
When ONTAP documentation refers to a disk type, it is the type used by ONTAP unless otherwise specified. RAID disk types denote the role that a specific disk plays for RAID. RAID disk types are not related to ONTAP disk types.
For a specific configuration, the disk types that are supported depend on the storage system model, the shelf type, and the I/O modules that are installed in the system.
The following tables show how ONTAP disk types map to industry standard disk types for the SAS and FC storage connection types, and for storage arrays.
SAS-connected storage
ONTAP disk type Disk class Industry standard disk type Description
BSAS
Capacity
SATA
Bridged SAS-SATA disks with added hardware to enable them to be plugged into a SAS-connected storage shelf
FSAS
Capacity
NL-SAS
Near Line SAS
MSATA
Capacity
SATA
SATA disk in multi-disk carrier storage shelf
SAS
Performance
SAS
Serial-Attached SCSI
SSD
Ultra-performance
SSD
Solid-state drives
FC-connected storage
ATA
Capacity
SATA
FCAL
Performance
FC
Storage arrays
LUN
N/A
LUN
Logical storage device that is backed by storage arrays and used by ONTAP as a disk These LUNs are referred to as array LUNs to distinguish them from the LUNs that ONTAP serves to clients.
Related information
