Manage Qtrees with System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to create, edit, and delete Qtrees.
Create qtrees
Qtrees enable you to manage and partition your data within a volume. You can use the Create Qtree dialog box in System Manager to add a new qtree to a volume on your storage system.
Steps
  1. Click Storage > Qtrees.
  2. From the drop-down menu in the SVM field, select the storage virtual machine (SVM) on which you want to create a qtree.
  3. Click Create.
  4. In the Details tab of the Create Qtree dialog box, type a name for the qtree.
  5. Select the volume to which you want to add the qtree.
    The Volume browse list includes only the volumes that are online.
  6. If you want to disable opportunistic locks (oplocks) for the qtree, clear the Enable Oplocks for files and directories in this Qtree check box.
    By default, oplocks are enabled for each qtree.
  7. If you want to change the default inherited security style, select a new security style.
    The default security style of the qtree is the security style of the volume that contains the qtree.
  8. If you want to change the default inherited export policy, either select an existing export policy or create an export policy.
    The default export policy of the qtree is the export policy that is assigned to the volume that contains the qtree.
  9. If you want to restrict the disk space usage, click the Quotas tab.
    1. If you want to apply quotas on the qtree, click Qtree quota, and then specify the disk space limit.
    2. If you want to apply quotas for all the users on the qtree, click User quota, and then specify the disk space limit.
  10. Click Create.
  11. Verify that the qtree that you created is included in the list of qtrees in the Qtrees window.
Delete qtrees
You can delete a qtree and reclaim the disk space that the qtree uses within a volume by using System Manager. When you delete a qtree, all of the quotas that are applicable to that qtree are no longer applied by ONTAP.
Before you begin
  • The qtree status must be normal.
  • The qtree must not contain any LUN.
Steps
  2. In the Qtrees window, select one or more qtrees that you want to delete, and then click Delete.
  3. Select the confirmation check box, and then click Delete.
  4. Verify that the qtree that you deleted is no longer included in the list of qtrees in the Qtrees window.
Edit qtrees
You can use System Manager to modify the properties of a qtree such as the security style, enable or disable opportunistic locks (oplocks), and assign a new or existing export policy.
Steps
  2. Select the qtree that you want to edit, and then click Edit.
  3. In the Edit Qtree dialog box, edit the following properties as required:
    • Oplocks
    • Security style
    • Export policy
  4. Click Save.
  5. Verify the changes that you made to the selected qtree in the Qtrees window.
Assign export policies to qtrees
Instead of exporting an entire volume, you can export a specific qtree on a volume to make it directly accessible to clients. You can use System Manager to export a qtree by assigning an export policy to the qtree. You can assign an export policy to one or more qtrees from the Qtrees window.
Steps
  2. From the drop-down menu in the SVM field, select the storage virtual machine (SVM) on which the qtrees that you want to export reside.
  3. Select one or more qtrees for which you want to assign an export policy, and then click Change Export Policy.
  4. In the Export Policy dialog box, either create an export policy or select an existing export policy.
  5. Click Save.
  6. Verify that the export policy and its related export rules that you assigned to the qtrees are displayed in the Details tab of the appropriate qtrees.
View qtree information
You can use the Qtrees window in System Manager to view the volume that contains the qtree, the name, security style, and status of the qtree, and the oplocks status.
Steps
  2. From the drop-down menu in the SVM field, select the storage virtual machine (SVM) on which the qtree about which you want to view information resides.
  3. Select the qtree from the displayed list of qtrees.
  4. Review the qtree details in the Qtrees window.
Qtree options
A qtree is a logically defined file system that can exist as a special subdirectory of the root directory within a FlexVol volume. Qtrees are used to manage and partition data within the volume.
If you create qtrees on a FlexVol that contains volumes, the qtrees appear as directories. Therefore, you need to be careful to not delete the qtrees accidentally when deleting volumes.
You can specify the following options when creating a qtree:
  • Name of the qtree
  • Volume in which you want the qtree to reside
  • Oplocks
    By default, oplocks are enabled for the qtree. If you disable oplocks for the entire storage system, oplocks are not set even if you enable oplocks for each qtree.
  • Security style
    The security style can be UNIX, NTFS, or Mixed (UNIX and NTFS). By default, the security style of the qtree is the same as that of the selected volume.
  • Export policy
    You can create a new export policy or select an existing policy. By default, the export policy of the qtree is same as that of the selected volume.
  • Space usage limits for qtree and user quotas
Qtrees window
You can use the Qtrees window to create, display, and manage information about qtrees.
Command buttons
  • Create
    Opens the Create Qtree dialog box, which enables you to create a new qtree.
  • Edit
    Opens the Edit Qtree dialog box, which enables you to change the security style and to enable or disable oplocks (opportunistic locks) on a qtree.
  • Change Export Policy
    Opens the Export Policy dialog box, which enables you to assign one or more qtrees to new or existing export policies.
  • Delete
    Deletes the selected qtree.
    This button is disabled unless the status of the selected qtree is normal.
  • Refresh
    Updates the information in the window.
Qtree list
The qtree list displays the volume in which the qtree resides and the qtree name.
  • Name
    Displays the name of the qtree.
  • Volume
    Displays the name of the volume in which the qtree resides.
  • Security Style
    Specifies the security style of the qtree.
  • Status
    Specifies the current status of the qtree.
  • Oplocks
    Specifies whether the oplocks setting is enabled or disabled for the qtree.
  • Export Policy
    Displays the name of the export policy to which the qtree is assigned.
Details area
  • Details tab
    Displays detailed information about the selected qtree, such as the mount path of the volume containing the qtree, details about the export policy, and the export policy rules.
Related information
